Question about Car Audio & Video
Location of speed sensor on my 1996 mustang gt 4.6 v8
  • 1,868 Answers
Hello! The Vehicle Speed Sensor (VSS) is located 1/2 way down the right-hand side of the transmission assembly...Wire colors are Gray/Black...
Pink/Orange...To test sensor...Disconnect plug...Read resistance across the two terminals of
sensor...Should read...190-250 ohms...
Guru........saailer
Posted on May 01, 2010
Production date February on 2007 mustang gt. Was told it only has 1 knock sensor. Wheres it located?
4 cylinders have 2, v6 have 2, v8 have 4
my book shows none for a straight 6
Oct 02, 2016 | Cars & Trucks
What all do I need to change when I put this 3.8 manual 5 speed 1996 model transmission into my 1999 4.6 Ford mustang I'm taking out the 5 speed that was in it what flywheel do I need and what else has to...
if both trans are identical then nothing not sure if v6 will fit v8 like bell housing, shifter location sensors. etc you may also want to think about will the v8 blow the trans from the v6
Feb 06, 2015 | Ford Cars & Trucks
Specify were the pcv valve is located on 95 mustang v8?
Look on top of the block at back by firewall for PCV. Other things you may want to check/clean are idle air control valve on side of throttle body, as well as mass air flow sensor in intake air assembly. Clean IAC with throttle body spray cleaner and port it is removed from well, and try. Use tuner cleaner or electrical cleaner on MAF sensor . Sometimes just cleaning will cure it.
Apr 09, 2012 | 1995 Ford Mustang GT
Where is the compressor's relay on a mustang 2000 GT V8?
The CCRM is located near the right fender apron, not far from the MAF sensor.
Aug 26, 2010 | Ford Mustang Cars & Trucks
83 mustang gt
In a 83 MUSTANG GT the correct answer is BOTH. As a 5.0L and a TURBO CHARGED 4 cyinder were offered.
1983 Mustang GT
  • Engine:
    • 5.0L horsepower increased to 175 HP when 4V carb replaced 2V carb from 1982 (Holley 4180C series).
    • Exhaust system was revised (less restrictive).
    • 4-speed SROD was only transmission available until early December 1982. In December, new 5-speed T5 became standard GT transmission (4-speed remained on option list).
    • Block and crank were revised to accomodate a 1-piece rear main seal in December 1982.
    • The new "Turbo GT" with a turbo charged 4 cylinder engine was available beginning late in the model year - 145 HP and featured the same suspension and other features of the V8 Mustang GT.
Jun 02, 2009 | 1983 Ford Mustang Hatchback
What is fireing order on 95 gt mustang gt/gts caneryyellow auto
5.0
V8 Firing Order: 1 3 7 2 6 5 4 8 Distrib. Rotation Is Counter Clock Wise
3.8
V6 Firing Order: 1 4 2 5 3 6
1 2 3
5 6 4 <<<<< Ignition Coil Pack Plug Wire Order
Feb 09, 2009 | 1995 Ford Mustang
What automatic transmission is a code p in a 1996 mustang gt. I think iy is a tremec t56.
your car has a ford AOD-E if it's an automatic, if it were a 5 speed manual it would be a T-45, the T-56 is a 6 speed manual transmission that was found in the 2003 and 2004 cobra models.
Nov 16, 2008 | 2002 Ford Mustang
Speed sensor removal 94 Mustang GT
Remove the trans cross member and let the trans drop down (use a floor jack), then you will be able to access it.
Sep 23, 2008 | 1994 Ford Mustang
Car Audio & Video Logo
308 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
