Question about Lands Phones
Serious problem with Samsung Blackjack
Samsung blackjack has a dead screen and keypad, nothing works. Screen comes on for 3 sec when the charger plug is put in or pulled out.
This is the third time the problem has occurred in warranty. The first time Samsung customer service (Melbourne) fixed it, but told me nothing of the fault or how to fix it.
The second time I rang and suggested the phone should be replaced. They refused. Then the phone repaired itself... (smart phone?)
This is the third time. I am on the verge of putting it down to experience.
    Genius:
  • 1,913 Answers
Hi
replace your battery.
reset your phone to default settings.
Posted on Mar 25, 2008
SOURCE:
I have a blackjack and it was working perfectly fine about fifteen minutes ago, i had it on the charger and it wouldnt charge, then it randomly started to charge then stopped and turned off by its self. I...
Try this:
1. Remove battery
2. Plug the charger or the USB Cable if you have it.
3. Place battery back in.
4. Let it charge (if it charges) all the way til you see green light.
5. Turn it on.
I hope that works.
Jan 05, 2011 | Samsung Blackjack SGH-I607 Smartphone
My cat had an accident on cell phone my charger, can it be repaired ? The charger does not work at all. Its a samsung blackjack charger. I plug it into my phone and nothing happens, as if no current is...
It could be either the AC adapter or the phone's charging unit and plug.
Neither is worth fixing.
I am sure that you can find a very inexpensive replacement AC adapter on eBay or by searching the Internet. Make sure you get the correct one as there are several Blackjack models.
If the charger doesn't fix it just get a new phone. Call your cell provider for deals or buy one on eBay without a contract.
If this helps please vote for my solution.
Sep 28, 2009 | Samsung BlackJack Smartphone
Samsung Blackjack II battery went completely dead and now the phone will not recharge. When plugged in, green recharge light will not come on.
Issue with either battery, charging port on phone, or charger. Attempt replacement of charger or different outlet first. Then battery replacement, about $50. Then phone replacement (hope you're eligible for warranty or have insurance if you don't want to upgrade).
Sep 28, 2009 | Samsung BlackJack II Smartphone
Samsung sgh-i607 got wet
mi blackjack got wet and it does turn on and it says that i have a text msg and that i have 3 missed calls buy the entire keyboard is not working,, what shoul i do?
Jul 08, 2009 | Samsung Blackjack SGH I607 Car Charger
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
It wont charge when on
The blackjack 2 starts to have charge issues over time. The light comes on but it does not charge.
1. Get repaired
2. New phone
Samsung BlackJack II not charging fix
Jun 23, 2009 | Samsung BlackJack II Smartphone
Blackjack just wont chage at all
Do a master reset of the phone. Sounds like a software problem since both the usb and power jack not working.
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
Apr 28, 2009 | Samsung Blackjack SGH-I607 Smartphone
My blackjack's keys wont work
First off, how do you know it's the keys, rather than something else? More details are always helpful. An important question is, can you see or hear anything at all, by any means? If someone calls you, does the screen light up?
If you see incoming calls, but can't answer them because the keys don't do anything, then I'd ask if the phone might have the keyboard locked. You'll be able to tell because you'll see "Unlock" in the lower left of the screen when someone calls or you press the power button (top left edge, above the screen). If it's locked, pressing the "..." button to the left of the wheel will tell you how to unlock it (just the "*" button down by the "0" button on my Blackjack).
If you don't see anything when someone calls, you might want to figure out if the phone is working at all.
A couple of ideas (sorry if any of these seem obvious - it's bad form to miss simple solutions):
1. Is the phone powered on? You can turn it on by holding down the power button (top left edge, above the screen) for several seconds. If you make it to 10 without the phone coming on, then it might be the screen, the battery, or the phone itself.
2. Is the battery dead? Try plugging the phone in and then holding down the power button, as above. If it still won't work, try removing the battery, then plugging it in and doing the same thing over again. When you plug the charger in, you should see a Duracell-like image on the screen, even if the phone is turned off. If you still don't get any sounds or anything on the screen, it sounds like the phone has serious trouble - probably needs professional help.
3. If you hear sounds ("swooshing" on mine) when you turn it on or off and the keyboard lights up, but don't see anything on the screen, it sounds like the screen might be bad - probably needs professional help.
4. Finally, you could try connecting it to your computer with the sync cable. I haven't done that with mine, so you'll have to read the instructioins, but it might let you know that the phone is working internally, but having communications problems through the keyboard and/or screen. If that's the case, you can try fixing it yourself or get an estimate from a professional. Good luck!
Mar 29, 2009 | Samsung BlackJack Smartphone
Blackjack II will not start
This has happened to my Blackjack II and I've found if I plug it into the charger then plug the charger into the wall, the phone comes right on. It's a pain, however, if I'm not at home when it decides to do this since no amount of button pushing will turn it back on, it acts like the battery is dead (when I know it isn't!)
BTW, I've have to have my SIM card switched out twice and the battery replaced 4 times since I bought this phone brand new in February......
Aug 30, 2008 | Samsung BlackJack II Smartphone
Lands Phones Logo
85 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
