Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman 17.5 HP B&S 42" lawn tractor that won't start. When I turn the key, the flywheel turns nearly one rev and then seems to stick. I turn off the key and manually turn the thing about 30 degrees, turn the key and it repeats. I have replaced the starter, solenoid, and battery.
  • 29 Answers
Ift.ts very possible you key is stripped on the crank shaft. Raise the hood and pull the air shroud which will expose the fly wheel, Remove the large nut holding the fly wheel and check for the shesred key. If it is sheared install anew one even if it has aneck in it.
Posted on May 01, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & stratton backfires & breaks flywheel key on starting
Be sure blades turning easy, one of spindel may have a bearing out or going out.
Nov 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Back fireing 22hp v-twin briggs, run but back fires all the time it's running. is this a valve or damaged flywheel key problem?
I dont think that it would keep running if it was a damaged flywheel key? Seems like eventually it would go on and slip too much. But a leaking valve sounds like the most logical answer. Take the spark plugs out and stick your finger over each cylinder and turn it over. see if one of em has more compression than the other. If one is take the valve cover off that one. and see if you can see a week spring or something.
May 11, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I cant shut off my lawn tractor with the key
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Jul 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor turns against its self
Sounds like the flywheel key may have started to shear and changed the timing. pull flywheel and check key.
Mar 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
273 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
