Question about Kenmore Elite HE4 Electric Dryer
Where can I down load a owners manual for a kenmore HE 4 dryer model 110.85091401
Where is ignitor in kenmore 600 series dryer
Posted on May 01, 2010
3 Suggested Answers
  • 35 Answers
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Posted on Jun 07, 2009
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
Go to Sears and buy it! You cheap B.
Posted on Jun 26, 2009
Dryer has a burning smell
My Kenmore 94702 dryer element overheated and the rubber inside the tub caught fire. Can anyone tell me how to find out if this problem has been reported by other owners of the Kenmore model or owners of the same model sold by the actual manufacturer?
Mar 20, 2012 | Kenmore 94702 Front Load Stacked Washer /...
How to hook up kenmore gas dryer model# 76512
You may download a copy of the owner's manual and installation instructions at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0705194.pdf
Dec 08, 2011 | Kenmore Dryers
I need to know how to fix the dryer belt on model 110.97574100 (gas dryer).Also is there anyway you can email an owners manual for this. I bought it new but lost the manual
http://www.searspartsdirect.com
Kenmore Gas Dryer
Model #11097574100
Owners Manual does not have drum belt replacement instructions, but service manual does. -- SWT
Aug 05, 2010 | Kenmore Dryers
I NEED AN OWNERS MANUAL FOR KENMORE DRYER MODEL #110.62052100,SERIAL#ML2001631.CAN YOU HELP?
Go to mangemylife.com and type in your model number under their "manuals" link. Your owner's manual should be listed in .pdf (Adobe) format that you can download or print for FREE. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 27, 2010 | Kenmore 72982 Gas Dryer
Need owners manual for sears kenmore elect dryer model 700.
Please visit THIS LINK.
Enter the FULL model number - then after choosing OK, the link to the manual will appear on the right side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 24, 2010 | Kenmore Dryers
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
I need owners manual to a kenmore dryer mod 110.60902990
Go to managemyhome.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Oct 27, 2009 | Kenmore Elite HE4 Electric Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
342 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
