Just installed windows 7 cannot enable wireless connection
  • 781 Answers
If you just installed win7 and you are having problems with an adapter on your computer that problem is usually related with the driver for that adapter and should be resolved by obtaining a proper driver for your new installed operating system.
if you computer was meant to support vista or win7 as per the manufacturer you can go to the manufacturer's website and attempt to get a driver for your wireless network adapter that works in win7. it's likely that you're manufacturer may not have that one yet but it's possible that one for vista may be out, download and install the vista driver for your wireless card and test the adapter to see if it works.
if you need help finding the driver, post back with your computer brand and model number. or simply go to the manufacturer website, go to the support area and look for driver or sofware download.
hope this helps!
Posted on Apr 30, 2010
Why my wifi disabled to connect
To verify the wireless network connection status, please go to the Network Connection Window. For Windows XP, Click on Start. Click on Run. Enter "ncpa.cpl" and click OK. For Windows 7 or Windows Vista, go to "Search programs and files" box. Enter "ncpa.cpl" and hit the Enter key.
If you see the wireless network connection icon is disabled in the Network Connections Window, you may double click on it to enable the connection. Should it is still disabled an no way to be enabled, you may have a AntiVirus software (for example, Kaspersky, ZoneAlarm, Trend Micro Internet Security...etc) installed in your computer and it disabled the wireless connection.
You may completely remove the antivirus software from your computer and restart the computer. Check the wireless connection can be enabled. Then you can re-install the antivirus software.
Jan 21, 2013 | TP-LINK Tenda W311R WirelessN Router AP...
How to go to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots. These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel. To connect to Wi-Fi, you must have an enabled wireless adapter on your computer. Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities. However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna. Hold the "Fn" key and press this key to toggle wireless on or off. Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter. Attach the USB wireless adapter to an available USB port on your computer. Windows 7 will automatically install the necessary drivers for most adapters. If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers. Restart your computer if you do not see a wireless icon in your Windows 7 notification area. Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect. If this is your home network, the correct network will likely be the one with the strongest signal. Click "Connect" and enter the wireless security passphrase, if required. Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead. Open your browser and navigate to any website. If the hot spot requires browser authentication, your website request is redirected to an information page. Follow the instructions on this page to get Wi-Fi. This may entail clicking "Accept," entering a given password or entering a cell phone number. After authentication, attempt your website again to verify accessibility. Hope this helps
b>
Dec 22, 2012 | Computers & Internet
Can not get to wifi
Hope this helps
Oct 29, 2012 | Acer Iconia Tab A200
Wireless not seeing internet but ethernet is
Try uninstalling the wireless adapter from the control panel. Reboot the system (although with Window 7 that shouldn't be necessary), and let it Windows auto-discover the device again. Disable/enable doesn't for Windows to re-install everything.
Jun 15, 2012 | Acer Extensa 5620 Notebook PC
Enable wireless for aspire kav60
Which Operating System?
The wireless button is for turning the wireless on or off, it sounds like you have the wireless adapter disabled.
Click Start/Control Panel or Start/Settings/Control Panel and look for Network or Network and Sharing.
If windows XP: when you open the Network just right click on the wireless connection and select Enable.
If windows Vista or Windows 7 when you open Network and Sharing look over on the left and select Manage Network Connections. Right click on the wireless connection and select Enable.
Jun 01, 2012 | Computers & Internet
I install a clean windows 7 in my acer aspre 5315 now it cant detect my wifi how to enable it
You may need to enable your Wireless adapter. You can do this by going into Control Panel then network connections. You should see a "Wireless LAN" icon. If you right click on it you can choose enable and then you can browse available wireless networks and connect.
Let me know if you have any questions.
-G33k
Sep 20, 2011 | Acer Aspire 5315 Notebook
I have a toshiba satellite PSL30A-00100E,, which has wireless LAN .. but when i try to connect through one of its programs it says please turn on the wireless lan, it does not have a switch or button to...
Sonu,
You can check firstly that if the wireless network card is installed properly, if so then check if its enabled in My Network Places ( Winxp) or Network and sharing center> Change adapter settings in windows 7 if you cannot find the hardware there, (Local Area Connection in xp) and (Wireless Network Connection in Windows 7) then restart the laptop go to BIOS and check for the Internal Devices and make it enable, it should work then or prompt you for the new hardware found
Regards, Bilal
Jan 11, 2011 | Computers & Internet
Wireless lan disabled. where is button to enable
for windows XP - go to control panel - network connection - eneble wireless LAN
for windows vista - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
for windows 7 - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
Mar 28, 2010 | HP Pavilion dv5tse Notebook
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
