Question about Nintendo Super NES Console
Hooked up Retro Duo to Sanyo 42" Big screen in video 1 Input but out of all three video channels on tv I am not getting a signal.....Almost like my tv does not recognize the system is plugged in to it. When I hook my ps 2 up to video one I have no problems.
2 Suggested Answers
  • 3 Answers
SOURCE: need help to hook up my nintendo retro duo to t.v.
In the cords & cables that came with your system, there should be one cable that has a place for cable ready tv and one for non cable ready tv. The non cable ready looks like the 2 wires that run from a tv antenna. If you have a cable ready tv you just use the screw on part like on a vcr. Also on the back of most newer tvs you will find what they call rca type plug ins. You can use them to connect it also. They are simple just follow the color codes such as white to white and so forth. There should have been an instruction sheet to show you this. I have noticed that depending on when it was built/shipped they have some that are shipping with the rca cables. If your tv is an older one and doesn't have the rca jacks in the back of it you have 2 choices that I can think of well maybe 3.You can upgrade the tv or you can buy a box designed to convert the older tvs to use the rca jacks or and most likely the simplest plug the rca cables into the back of a vcr.The last suggestion will not require the vcr to be turned on. It will work on a simple pass through. The vcr will work as normal with all other functions it has and it gives you the option of recording you playing the game so you can prove the levels you made and also show you mistakes you made in losing the game. I hope this helps I tried to keep it as simple as I could for all to understand. So please don't think I was trying to talk down to or above the head of anyone.
Posted on Jan 04, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I hook up the Retro Duo nes/snes system to an older tv that has no a/v connections. I do have a Direct tv cable box but when I hooked the a/v cables to it absolutely nothing happened
Do you have a VCR that can hook to the TV that has the proper hook ups for your game system? Be sure your TV is on proper channel for your VCR to work (test it with a VCR tape and see if it plays) then change your channel on your vcr until it shows your game you have in your system hope that helps good luck
Dec 11, 2014 | Retro-Bit Retro Duo NES/SNES System Mascot...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
New sanyo hdtv and old vcr...can't get menu to appear on screen
there is an input or input select button that gives you cable,hdmi and video composite,to run the vcr. hook up cable and put the tv on channel3 to make sure that works first,then play with the rca cables. keep in mind a tape has to be playing,the new tv have a signal sense circuit,if there is just "snow" you get a blue screen
Jul 22, 2009 | Goldstar GVR-E435 VHS VCR
DVD player hooked up, no auxilliary channel
I also have this ******* problem and apparently there is not solution. So just remember, next time you wanna find the urge to buy a ******* sanyo...dont do it. Sanyo = Bigfoots ****!
May 15, 2009 | Sanyo DS19310 19" TV
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
Nintendo Super NES Console Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
