Shutdown/Startup repair issue
I have an issue with my ACER 7520 laptop. A message appears "configuring updates, 1 of 3 please wait" It then attempts to shutdown and reboot. I then get a message stating it was unable to start up, so Start Up Repair will begin. This does not complete, so when going into the diagnostic there is an error message _"Boot critical, cwindowssystem32drivers dis.sys is corrupt". This initially happened after I downloaded BBC IPlayer, managed to revert to the system prior to this update, all appeared Ok but problem has resumed
    Guru:
  • 377 Answers
Hi dear
The process NDIS 5.1 wrapper driver belongs to the Microsoft Windows Operating System.
Description: File NDIS.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 182912 bytes (94% of all occurrence), 167552 bytes.
The driver can be started or stopped from Services in the Control Panel or by other programs. The file is a Windows core system file. The program is not visible. It is a Microsoft signed file. The service has no detailed description. Therefore the technical security rating is 0% dangerous.
This is a common problem experienced by many people. Just Google NDIS.sys and you'll see what I mean. For some it is onboard sound such as Realtech, others it is IRQL conflicts, and for still others such as yourself the NIC card.
One person worked around it by uninstalling the Windows driver and downloaded the manufacturer's driver.
oke
Posted on Mar 25, 2008
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
My laptop says windows error recovery
The Windows Error Recovery message can appear for several reasons- an improper shutdown, new software, new hardware, etc. Since trying both options that you are given doesn't work, you need to troubleshoot the Windows startup error. If you have recently added new hardware, disconnecting or removing it could solve the problem for you as it might be creating some type of incompatibility.
Troubleshooting Windows Error Recovery: Last Known Good Configuration
You can attempt to boot up in Safe Mode and select Last Known Good Configuration and see if that works to resolve the Windows startup error. Turn the computer on and immediately begin to press the "F8″ key. If this does not work, you might need to press the "F2," "F10," or "F12″ key. Once you see the prompt screen, select "Last Known Good Configuration."
Troubleshooting Windows Error Recovery: Booting up from the Installation Disk
If that did not work, try booting up the laptop using the Windows installation disk - provided you still have it. If so, follow these steps:
1)   Turn the power button to your laptop on.
2)   Immediately insert the Windows installation disk that belongs to the laptop.
3)   When you see the option for "Check System," press the "ESC" key. Next, press the "F1″ key. Your laptop should now boot up.
4)   You can now use the "System Restore" feature to allow your laptop to return to a previous setting when it was functioning properly. This might mean selecting "R" for recovery.
Mar 11, 2011 | Acer Cell Phones
I want to reset my laptop to it's factory settings.
hello.push DEL or F2 immediately after powering on.
Than your are in the bios
push F5 confirm
push F10 confirm
restart the pc
try recovery again
Jun 30, 2010 | Acer Aspire One PC Notebook
Cant get windowes to start
turn the unit on and start pushing F8 while the unit is starting. It should take you to the windows startup options. Select start in safe mode and see what happens. In safe mode you can repair several issues, especially start up and shutdown issues.
Apr 07, 2010 | Acer Aspire 7520-5185 Laptop
Acer aspire 7520 laptop has overheated diodes on motherboard
what is the start up issue, how far dose it go. do you get the login
Mar 09, 2010 | Acer Aspire 3680 Laptop
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
I got an acer aspire 7520-5185. my friend had the hadrive cleaned out. when i turn it on it says bootmgr is missing press ctrl alt delete. what do i do to fix this? jedy ponders lol
Use the Startup Repair option in the Windows Recovery Environment
Put the Windows Vista installation disc in the disc drive, and then start the computer.
Press a key when you are prompted.
Follow the procedure
Click Repair your computer. then follow the other procedure..
In the System Recovery Options dialog box, click Startup Repair.
Restart the computer.
Dec 30, 2008 | Acer Aspire 7520-5185 Laptop
Shutdown
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
