Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Screen going blank on fujitsu siemens amilo L1300
Hi my laptop screen is going blank but not totally i can still see faintly underneath i have tried reseating the cables attached to the inverter board and havent any other ideas can someone help
Hi
my laptop is perfect from everywhere but the problem is it does not shows the display.can u give me any solution to solve this problem
Posted on Aug 01, 2010
  • mr_ather2007 Aug 01, 2010
    hi \r\n my laptop fujitsu siemens is perfect but the problem is it des not shows the display due to VGA problem.give me any solution to solve this problem
    Genius:
  • 1,913 Answers
Hi
change place og your magnetic device nearly to display if there.
reset your monitor.
degauss it.
also check your cpu display option with other display if u have.
Posted on Mar 25, 2008
Fujitsu amilo Si3655 laptop screen coming blank
It Sounds Like The Problem Is Caused By Settings For A
Screen Saver You Have Enabled! If This Is Correct Then
All That Is Needed Is To Ajust The Settings Or Disable It
Completely! See The Manual For Both The Laptop And The OS For Further Details!
Apr 02, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Does the value of a battery capacity(mAh),larger than that specified for a laptop,mean any damage when used with it?
No it doesnt.. It just means that the battery can hold a larger charge.. I.E. the laptop will run longer then one with a lower mAh..
Mar 14, 2013 | Battery Biz Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
My siemens amilo d7830 the screen is showing blank. any idea please
Press
Fn+F8 then it might be working.
If that does not work then try;
Fn+ CRT/LCD
Dec 30, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo L1300 don't boot anymore
you have lost the bios is you bios chip emovable in a plastic holder if so replace it if not buy a motherboard
Apr 07, 2009 | Computers & Internet
Fujitsu siemens amilo L1300 LAPTOP wont load up
sounds life the start up files have been corupted you may need to reinstall windows. the only thing is it will delete and data you have on the labtop. if you dont mind about that reinstall windows of the reinstalltion cd.
Mar 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens lap top AMILO l1310G
Try reconnecting the LCD cable on the back of the screen. You have to open the screen in order to access the lcd cable.
If this won't work, the cable is most likely not working correctly.
Oct 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Blank screen
Sometimes an easy solution to this is to turn off your laptop completely, remove the power lead from the socket and the laptop, then remove the battery, leave for a couple of minutes and then try again.
If this does not work, then you are into the realms of programming / restoring.
I hope this helps you, Chris
Oct 27, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
1,005 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
