Question about Sewing Machines
Many skipped stitches when free motion quilting
    Genius:
  • 1,116 Answers
Change to a 100/16 needle and slow down the motion.
Sewing machine needles have a groove down the front of the needle shaft which helps guide the thread through the needle. The more room, the better the thread is guided.
You should able to find more about this at Quilting Arts TV (Internet) - one of my favorite PBS shows.
Posted on May 01, 2010
How do I set 8900 for free motion quilting? D4S mode and QB-S foot
To do free motion quilting on most machines, install a darning foot or free motion quilting foot, drop the feed dogs, set the machine to straight stitch. (Because FMQ requires you to manually maneuver the fabric, stitch length is moot.) If your machine has the feature, setting it to Needle Down will also help. When you stop sewing, the needle will stop while penetrating the fabric. This prevents you from accidentally moving the fabric while trying to adjust before sewing again.
Free Motion Quilting Beginner Tutorial 1 of 4
Jan 11, 2017 | Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Learn How to Free Motion Quilt Stippling
Oct 31, 2016 | Janome Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Aug 29, 2014 | Husqvarna Sewing Machines
I am having problems with my Juki TL98E skipping stitches when I free-motion quilt. I have cleaned it well, put in a new needle but still having problems. When I stitch forward, it's ok, but when I try to...
It is a timing issue. I have a TL98E. The needle bends a bit when free motion quilting, moving the needle away from the hook, thus missing the thread. Try to put in a larger needle, or have the timing changed so that the hook "kisses" the size needle that you want to use. Tammy
Nov 18, 2010 | Juki TL-98Q
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
When machine quilting sews fine when moving forward, skips stitches when moving away
Check your needle. Make sure it is not blunt, try a Size 90 Topstitch needle or Embroidery needle. If you are using a thread thicker than regular piecing weight, you need a needle with a larger eye and a larger scrarf - the hollowed out bit at the back of the needle. Also don't sew too fast nor change direction too sharply. If you need to do a sharp turn, let the machine "mark time" once at the turn before moving off in the new direction.
Pam
Apr 28, 2009 | Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
209 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
