Question about Fiskars Brands Fiskars 10" Power - Lever Hedge Shears Wood
How do you reassemble a fiskars pruner? - Fiskars Brands Fiskars 10" Power - Lever Hedge Shears Wood
I cannot open my Fiskars pruner for smaller hands. It says to press on the orange round side pieces, but I am not Hercules.
Use both hands, one to hold the pruner + the other to press the orange clips .
Apr 28, 2018 | Garden
Need to replace the short rope inside the pole of my fiskars powerstroke hand pruner tool so where can I find that?
go to a hard ware shop that sells cords and ropes and make it using the old one as a sample
May 08, 2016 | Garden
How do I unlock stuck blades on Fiskars pole pruner?
Just undo the bolt in the centre of the jaws. Tree Pruners
Oct 04, 2015 | Garden
How do I prune a peach tree
Do you wish the tree to produce a lot of fruit or to be a pretty tree. The trimming process will be different depending on what you wish.
Oct 09, 2014 | Fiskars Telescoping Pruning Stik Tree...
The ******** the Fiskars Power-Stroke pole pruner has become slack and won't open and shut the pruner blades. Would appreciate your help. Thanks.
Hi, you need to clean the blades and dry them and spray some WD-40 on any thing metal spring, blades, nuts, bolts. They get a build up of tree sap from cutting, regular cleaning and coating them with oil will prolong the life of any metal tools, also when you clean them make sure they are closing all the way without gaps. You may need to adjust the blades by adjusting the screws, take your time and adjust slowly so you turn in the right direction continually checking the gap.
Aug 04, 2011 | Garden
Instruction manual for pole pruner attachment
Do not use as a coaster.
Do not use to stabilize a wobbly table.
Your pole pruner is not edible.
Do not taunt your pole pruner.
Your pole pruner is not a parachute.
Do not feed your pole pruner after midnight.
Do not use pole pruner to commit armed robbery.
Do not name your pole pruner Carl.
Do not marry your pole pruner.
Do not turn your back on your pole pruner.
Jul 25, 2011 | Flamebrain Technologies WatchMe
Sawblade fortree pruner #7186392
Your Craftsman Tree Pruner is a 1993 model. Sears no longer sells the replacement blade. The pruner was made by Fiskars for Sears. Check out their replacement blade Fiskars # 9333.
Oct 03, 2009 | Craftsman Garden
Fiskars Brands Fiskars 10" Power - Lever Hedge Shears Wood Logo
351 people viewed this question
Top Fiskars Brands Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fiskars Brands Garden Expert? Answer questions, earn points and help others
