Question about Bosch Nexxt 500 Plus Dryer
Heat stopped working - Bosch Nexxt 500 Plus Dryer
  • Bosch Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
Heat pump fan will not stop running
could be a heat sequencer. if the stat was bad it would run constantly in both modes.
Nov 12, 2012 | Heating & Cooling
My motorhomes Eberspacher combitronic heating no longer works on 240v although still heats water and heats on diesel.
Hi l had exactly the same problem with my combitronic, tried virtually everything, asked & took my motorhome to several places found one that could find the fault. Apparently there was a break down of a wire under the sheathing stopping the heating working on 240v. Agency supplied if required.
Jul 23, 2012 | Dryers
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Laptop stops wafter some working heating
I THINK you mean, Laptop stops working after heating up... If that is so, that means your Cooling system is not functioning, and the computer has turned itself off to protect your MOTHERBOARD, CPU, RAM and HDD from heat damage. Which means, you can likely get your cooling fan replaced in a shop for about 100 bucks (outside of warranty) and have your pc back the way it was when you got it new.
Aug 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Saturn VUE 2004-Heated seats just stopped working. Fuse is fine..
This is not un- common. The heating elements do wear after a while. It is probably an open circuit in one of the pads in your seat. A quick restance check can determine which one it is.
Jan 02, 2009 | 2005 Saturn VUE
Drum runs, but no heat
i would first look at the heating element. check for continuity.
Feb 08, 2008 | Dryers
Bosch Nexxt 500 Plus Dryer Logo
67 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
