Question about Dryers
GAS Dryer starts and then stops after a minute or less.
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Most of the time when the symptom you describe occurs the flame sensor has failed. It does not sense a flame and as a by design fail safe shut off the gas safety valve.
However... if the burner never does light then there is another fail safe in that being an automatic shut off of the dryer when the burner does not light at all on units with electronic timer controls.
A weak gas valve coil can also cause an early shut down. I.e they are powered, open the gas valve but, can't keep it open.
If there is no airflow... i.e the blower fan hub has failed and it is not turning the burner flame will cause the high limit thermostat to trip. After about 5 minutes you would be able to restart the dryer only to have the whole evolution repeat.
You did not mention a make or model number so it is difficult to go into details on exactly what to do to rectify your dryers' shutting down problem.
Thanks for using FixYa,
Kelly
Posted on Apr 30, 2010
No heat while drying
If this is a gas dryer. It's possible that the solenoid gas valve has gone bad. One way to determine this is by do a dry cycle and listen to the gas and flame to start. It shoudl sound like a flame starting on a regular stove top. Once the flame starts you can hear the flame. If the flame stops in less than a minute that is an indication that the gas valves has switched off. You need to have the solenoid valve replaced.
Mar 01, 2011 | Whirlpool Dryers
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
My roper gas dryer doesn't heat and the timer dial does not advance. I recently cleaned out the interior ductwork, it worked fine for a week, and then it seemed like the timer started becoming less and ...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 28, 2010 | Roper REX4634KQ Electric Dryer
My new Perfect Care Gas dryer stops with in a minute of running.
Check your thermo coupler (flame sensor). If it's new it should have a warranty I would think.
Apr 10, 2010 | Whirlpool WED5520SQ Gas Dryer
Maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
Feb 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
