Question about Broan-NuTone VX475 Bagged Central System Vacuum
I have the vx475 & it smells like burnt rubber. Help!!
    Sergeant:
    Champion:
  • Broan-NuTone Expert
  • 357 Answers
Your motor is burning up. If it is under warranty call the warranty station. If not take it to a vac shop
Posted on May 01, 2010
When operating smells like burnt rubber. Roller brush stopped turning.
Hi leanneaj...
Your problem is caused by hair,strings,etc getting around the beater bar at the ends of the roller where the bearings are and causes it to sease up.
The smell you smelled was rubber burning, the rubber belt that operates the roller brush has burned into...broken.
You will have to remove your roller brush and clean, and oil and then reinstall it with a new belt
Please take time to rate me
Sep 04, 2011 | LG LUV300B Bagless Upright Vacuum
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
My dyson dc07 has started to smell a bit of burning.
This will be 1 of 2 problems.
1. If its a burnt rubber smell then its the belt that has gone and will need to be replaced.
2. If its a metalic smell then your motor is burnt out.
Replacing the belt is easy enough, the motor is a lot more complicated and should be left for an expert.
Feb 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Vacuum cleans properly,however smells like rubber. Nothing is caught in belt
You need to replace the vacuum belt. Even though the belt may look fine it is probably stretched or worn and slipping on the motor shaft and that is why there is a burnt rubber smell. You can get replacement belts here:
Replacement Vacuum Belts
Oct 31, 2009 | Vacuums
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
FAN PROBLEM???
There isn't any belts, and the fan wouldn't be rubber, so not sure what you are smelling. Maybe this picture will help you.
Dec 30, 2007 | Bissell 6700 Butler Revolution Bagged...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
139 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
