Question about Hunter Ceiling Fan Control Switch
Hunter fan.black,gray,brown,green switch L 1,2,3
Hunter fan.black,gray,brown,green switch L 1,2,3 replaced switch with after market product that appeared to be the same. cannot get the middle speed.
    New Friend:
L = Black
1 = Grey
2 = Brown
3 = Green
Posted on Apr 01, 2013
  • Anonymous Mar 06, 2017
    I have the same problem as nannypappy. Rachel has identified the color scheme of the original switch correctly, however, some aftermarket switches do not hook up the same. I have just experienced this problem and am working a fix. I might open the old closed switch and fix it, instead. The problem is in the switch.....not with the installer. I'd work it out. Call an electrician and pay all that money for this kind of fix? Not if the installer has a brain and knows how to work safely with electricity.
5 Suggested Answers
SOURCE: hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Posted on Nov 29, 2008
  • 78 Answers
SOURCE: I have older Hunter 3
if you know how you can open the switch and fix it
Posted on Jan 20, 2011
SOURCE: pull switch wiring schmetic
Call an electrician
Posted on Feb 12, 2009
  • 34 Answers
SOURCE: The middle speed on my 11 year old Hunter ceiling
I think it was becuase of the incorrect wiring. Call an electriction to fix it.
Posted on Jul 01, 2010
I have an older hunter Seville 3 speed motor and need the proper positions for the green brown and gray to the ze 268s2 switch
Try this; 1 - green 2 - gray 3 - brown L - black
Is the switch you have from Hunter or did you buy it off a rack somewhere? The switch could look the same on the outside and be different on the inside. fanman9952@aol.com
Jan 28, 2015 | Hunter Dryers
I needed to replace the pull switch, but in doing so the capacitor was disconnected and I do not know where the wires go. It's a five wire, 2 gray,1 green, 1 red, one brown. It's marked 10mfd/5mfd/250vac....
1 - gray
2 - brown
3 - green
L - should be black
The other gray should be connected by wire nut to the other grey to reversing switch.
Also, you should have two wires, white & black w/ white stripe, at bottom of fan to hook up light if needed.
Oct 08, 2013 | Hunter Dryers
I just replaced the switch in my hunter ceiling fan. I put L - black; 1 - gray; 2 - brown; 3 - green. Now the problem is that it won't turn off. I just have 3 speeds that go faster. This is not...
You got the wrong switch!!!! Just because it looks the same on the outside(switch) doesn't mean it's the same on the inside. Call 1-888-830-1326 with your model # and order the correct switch.
The model # will be 5 digits starting with a 2
Aug 17, 2013 | Hunter 20761 52'' The Stratford II Brushed...
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Need wiring diagram for 4 wire switch
I have similar problem, although I have 1 high speed and 2 lows, no medium. before I replaced the switch (which was no help) I marked the wires.
L= Black
1= Grey
2- Brown
3= Green
Apr 08, 2009 | Hunter Ceiling Fan Control Switch
Hunter cieling fan switch replacement
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Dryers Logo
1,092 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
