Question about Kenmore 24032\24036 Top Load Washer
Black debris particles sticking to clothes
White sheets come out dirty, isolated it by removing the sheets while some water is in the machine. the spin cycle had been making these particles stick to the sheets. I see the particles floating in the bottom, suspect a seal may be disintegrating. I was able to rinse off this debris with a hose once the sheets were on the clothesline (so not grease). parts list shows a tub ring and gasket, m I on the right track?
some years back I had the coupler or sub coupler (he described it as a bushing) between the trans and motor replace, the agitator is quite noisy, suspsect that may be failing again, may or may not be related??
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
It's very un-likely that the Motor Coupler can cause black spots on clothes. It's far enough away from the tub and basket that even if it were wearing, the black rubber would drop to the floor instead of moving up.
It could well be the gaskets in the outer tub.
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (likely gasket) it's certainly less expensive than calling in a repair person and gives you a chance to thoroughly clean the washer.
While you have the washer apart, it might be a good idea to replace the motor coupler again. (A $15 - $20 part)
Posted on Apr 30, 2010
How do I clean a build up of dust behind the mesh on the cyclone shroud of my dyson dc59?
Hi William, it's Jack at Dyson.
It's normal for harmless static generated in use to cause fine dust particles to cling to parts of the clear bin and cyclone pack. This will not affect performance as airflow doesn't have to pass through this dust, and it's not necessary to remove dust particles from behind the mesh shroud. When you empty the machine after use, tapping the cyclone pack gently will help dislodge any clinging particles.
You can remove any fluff or debris from the mesh shroud itself by removing the clear bin. To do this, press the red bin release catch once as if you were emptying the machine. Then with the bin base still open, press the red release catch firmly a second time to disengage the clear bin.
A soft brush or a dry cloth can then be used to remove any hair or debris from the shroud.
Aside from this, the only other maintenance needed is to wash the pre-filter at least once a month using cold water without detergent:
Always ensure the filter is completely dry before replacing it in the machine - this may take at least 24 hours.
I hope this helps, but if any further guidance is needed you're welcome to give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 29, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
How to clean washingmchine internaly
Need to establish if the dirt was from the washing or the machine. Do another wash (hot with dirty or dark clothes which don't matter (or empty) and wash out your machine. Then wash again with a white low value sheet and see if problem persists. If it does, your machine bearings may need replaced, .
Dec 09, 2013 | Washing Machines
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
How do I remove crud from inside a washing machine?
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
12.2 Soiling
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
soft water.
12.3 Linting
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
12.5 Black Marks on Clothes
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
12.6 Grey Marks on Clothes
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
12.8 Tangling
other. Do not load SmartDrive by wrapping clothes around the agitator.
Dec 19, 2012 | Fisher and Paykel Washing Machines
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
I have a brother 770 fax. When making copies or sending faxes the paper has long black narrow lines running from the top to bottom. Please help.
Hi There!
One reason why you're having a black line on the copies you make and faxes that you send it's because the scanner glass inside the fax machine is dirty. Here's what you can do to resolve you're issue.
-Make sure the printer is off and unplugged from the power outlet for your safety. -Open the control panel, Prepare a dry lint free cloth and isopropyl alcohol, dampen the cloth with a small amount of alcohol. -Inside the fax machine look for a the long scanner glass clean it with the dampened cloth, using hand try to feel if there are debris or dirt and concentrate on cleaning that part. -Directly above the glass you will see a white strip clean that also with the dampened cloth
Once you're done cleaning, close the cover and plug it back in. Try to copy a blank sheet of paper and if you can still see the same line clean it again for about 3-5 times, Make sure to make a copy everytime you clean the glass.
Hope this helps!
May 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Poor quality printing - cleaned print head, corrected nozzles, replaced cartridges but still only prints half a page. Today it told me to check the USB cable as there was no communication. I checked and...
Instructions Things You'll Need:
  • Small bowl
  • Water
  • Lint-free cloth
  • Tweezers
  • printer paper kit
  1. Turn off the Kodak Printer Dock, if it is on.
  2. Pull the paper tray from the printer.
  3. Check the exposed paper slot for paper fragments and/or jammed sheets of paper in the slot. Use tweezers to remove any paper fragments from the paper slot.
  4. Fill a small bowl with one-half cup of cold water. Wear latex gloves to keep your hands from getting wet.
  5. Dip a lint-free cloth in the bowl of water. Wring out excess water.
  6. Wipe the paper-feed rollers located in the paper sloth with the damp cloth. Turn the rollers with the cloth to remove any caked-on debris from the rollers.
  7. Turn the cloth to a clean side. Continue cleaning the rollers until the debris is gone.
  8. Let the paper-feed rollers air dry.
  9. Remove the paper from the paper tray. Fan the paper to keep the sheets from sticking together.
  10. Reload the paper tray with additional paper from a printer paper kit. Place the new paper below any older paper in the paper tray. Do not load more than 30 sheets of paper.
  11. Reinstall the paper tray. Print a test picture to check the Printer Dock.
Feb 02, 2011 | Kodak ESP 5 Printer
White residue on black clothing
I am sure you did not wash dark clothes with white, right?
How old is the washing machine?
Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
What type of soaps are you using?-- any chance they could be causing the residue?
How hard is your water? (Do you have a water softener in the water system?
Please tell us more about your circumstances.
Mack B
Dec 28, 2010 | Washing Machines
I have a 5E error on the diplay of my washing machine with the clothes locked inside and with no solution whatsoever .... Help Please
If its a samsung model, which I am assuming it is as I have just had the same error code, it means you need to clean your debris filter.
If its a samsung washing machine...to clean the debris filter you need to open the panel which is located on the front of the washing machine on the bottom right (you will need a coin or a key to do this) When you do you will see a large black plastic screw on the left and a small white plastic screw on the right.
The 1st thing you need to do is pull out the white screw (this is the emergency drain hose) have a bowl or bucket ready (the hose doesnt reach that far) and pull of the white knob (i had to kind of twist and pull, a little harder than i thought)
After you have drained the water you can now clean the debris filter (the large black screw) Have some towels or another bowl or bucket ready underneath as more water will drain. When all gone you can twist off the black screw and remove anything blocking (I had a coin and a plastic wrapper and some tooth picks. No more error message.
Good Luck!
Jul 25, 2010 | Samsung Washing Machines
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
345 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
