Question about RCA D52W19 52" Rear Projection Television
I have a 52 in Rca rear projection tv it has a red out line on everthing I haved cleaned mirrow and lenses and inside and outside of screen what do I need to do
  • RCA Master
  • 3,459 Answers
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
I HAVE DOBBLE AND TRIPLE VISION HOW DO I FIX IT
This is caused by a blown fuse on the convergence circuit. There will be missing menu items in the service menu as well when this fuse is blown. You must replace the small block type fuse and then enter service menu and converge the television back to normal. This requires removal of the main board, unsoldering the component and replacement, and then alignment.
Apr 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 in rca projection screen tv that looks like its stuck in 3d mode, how do I fix it?? Its got red and green lines everywhere. It was in storage outside for 6 months as well
It has dust on the lenses. My RCA rear projection uses a 7/64" allen key. take the speakers' cover off and then remove (I think) the three screws below the button pannel, and 2 on each side on the back on button pannel. the projectors should be easy to see. I turned mine on when I cleaned the lenses so i could tell if there was any streaks.
Once the lenses are cleaned go to auto convergence in the setup menu and your problems should be fixed. Good Luck.
Mar 09, 2010 | RCA Televison & Video
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
How do i take of the front cover of my 52 inch RCA hdtv? i need to clean out the inside of the tv because spiders somehow got behind the picture...
You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Is there any way that a rear projection screen can be cleaned? That is the inside of the screen not the outside.
Most definetly. There are three guns that have lenses that should be cleaned they are heavy glass and can be cleaned with lens cleaner or a mild glass cleaner. There is also a mirror that needs to be cleaned. If it is glass its easy to clean, however it maybe mylar in which case you have to be very careful cleaning it. Can make a major difference in picture quality.
Sep 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Cleaning rear projection screen tv
It is very rare to have to clean the mirror. It us upside down so it does not collect dust. It does however collect nicotine if there is a smoker in the house. Some RCA mirrors are not glass and should not be touched. The lenses do get dusty and should be cleaned.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
I need replacement screens
the inside screens for this tv is screen assmbly rca part number 258513.. the outside plexi is known as the "supersheild" rca part number 258797
Apr 05, 2008 | RCA D52W19 52" Rear Projection Television
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
