Question about Paradigm Titan Speaker
No sound out of subwoofer unless I gently push it
No sound out of either subwoofer unless I gently push it in, then sound quality is fine
  • 616 Answers
Speaker is close to needing replacing
Posted on May 01, 2010
My gigaware subwoofer wont work
Audio subwoofers are used to augment the sound quality that is released by stereos and other audio component systems. As a result of actively using subwoofers, the sounds projected from the sound systems (such as music and voice) not only become louder, but also have a fuller output. Subwoofers, however, are not immune to problems. These issues often result in distorted sound.
Issues Among the most common problems of audio subwoofers is the loss of their bass effect while playing music or other sound files. The majority of people that experience this problem do so because they have installed their subwoofer on a different sound system than the one where it was originally installed. Additionally, there are scenarios where the subwoofer does not produce any sound. b> Troubleshooting b> Subwoofer issues are typically caused by one of two things: improper settings or broken receivers. You can troubleshoot the lack of bass or other sound effects that decrease the quality of sound by checking and adjusting the settings of the subwoofer as well as your audio system. Although subwoofers work on almost all types of audio systems, some have to be adjusted to ensure quality sound while utilizing them. Broken receivers, on the other hand, have to be replaced with new ones. b> Significance b> Fixing subwoofer problems proves to be important, not only because it will increase your enjoyment while listening to music, but also because utilizing a subwoofer improves the audio system's overall performance. When subwoofer issues go ignored, there is a tendency for the audio system to become overworked, as the user likely works the controls on the audio system rather than using the subwoofer's settings. As a result, additional audio problems may arise due to playing at full-blast volume and making other unnecessary adjustments to compensate for the lack of a subwoofer. b> Recommendations b> One way of handling subwoofer issues is by reviewing the owner's manual, paying special attention to the speaker settings. Different audio systems have their own recommended settings to ensure quality sound and that all the effects can be felt and heard while the sound file is being played. If the manual does not provide any recommended settings and/or adjustments, tweaking can be done on the audio system's subwoofer menu to create your preferred sound. Through tweaking, you will be able to find the desired quality, as well as detect and correct any unnecessary noises and vibrations coming from the subwoofer. b> Maintenance b> Audio subwoofer problems can be prevented by regularly cleaning and maintaining both the subwoofer and the audio system where it is connected. The speakers should be dusted off periodically to ensure clean release of sound and the wiring should be checked for open exposures. These exposures should be immediately repaired to prevent further damage. Fix a Subwoofer b> A subwoofer, or a "sub," is an important part of your overall sound system, whether it's in your home or car. A sub's most important quality is bringing out sounds you can feel rather than just hear. However, they are also susceptible to wear and tear from overuse, and the sound quality will be greatly affected by this. Here are some steps to fix a subwoofer.
Check with your manufacturer's Tech Support Web site. Usually with a subwoofer, the problem lies with the voice coil, which might just be burned out. These are usually fixed by sending them into the manufacturer, so determine how much you want to spend to repair it versus how much it would cost just to buy a new one. Roam through the Tech Support forums. It's likely that someone had the same problem as you with your sub, and you can run the symptoms past a few other consumers to see what diagnosis they found. Identify the specific problem if you can. You can look for tips to fix this problem on the manufacturer's Web site, or if you're technically savvy, you can try opening the sub and looking at it yourself. Two major manufacturers of subs include MTX and MK Sound. Check the bronze-colored coil underneath the foam cover. Note whether it looks worn, burned, warped or distorted. This may be the cause of your sub sounding fuzzy or muffled, which means it needs replacement. Look at the fuse inside the speaker and test it if you know how. This is a likely problem that causes your sub to power up improperly, play sounds at about half the volume or intermittently fade in and out. If the fuse is discolored or shows a short, you'll need to replace it.
b>
Jan 28, 2013 | Computers & Internet
Why is the subwoofer making a buzzing sound? Is there a solution?
I have had the same problem with my Sony sub. It sounds like it is picking up electrical noise and would not go into standby when the reciever was off. I rerouted my wires and changed to a much higher quality wire. I was using a very low quality stranded copper with thin insulation to start with.
Jun 14, 2010 | Sony SA-WM20 Subwoofer
My boyfriend has pioneer surround sound speakers for the house and on the subwoofer my daughter pushed in the dome what is the best way to get the dome back out
A vacuum works good, or some good tape. It's only a dust cover for the voice coil. It does nothing for performance of the speaker, unless it's loose and it will vibrate and sound bad and the you can re-glue the edges.
I'm sure your daughter feels bad, but let her know that she did not damage the speaker at all, it will be just fine.
Jun 26, 2009 | Car Audio & Video
My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Mar 13, 2009 | Kicker 06CVX122 12" COMPVX Subwoofer,...
2 DHD NTX-6812 car subwoofers
First you'll need to buy a good quality amp wiring kit. For the torture your battery receives, get a power cap. The higher the farad the better off. And as for sound quality use really good RCA's and speaker wire. Try to keep the amp as close to subs as possible, and speaker wire a the necessary length. Not to long. Be sure to have a good ground.
Dec 03, 2008 | DHD NTX-6812 Car Subwoofer
Blown speaker?????
just gently push on the sub if it makes a noise like a grindin sound its blown.if it dont glue the center back on
Feb 25, 2008 | AudioBahn AW1251 Car Subwoofer
Smoke coming out of subs
If smoke has come out of the subwoofer, the speaker itself, that means the voice coils have been heated excessively and they are damaged or in this case, I'd say completely blown. Voice coils blow because they've been driven too hard, too much power, too much distortion for too long.
If you can get access to the front of the subwoofer speakers, gently put even pressure with your fingers near the middle of the cone, just around the edge of the centre dust cap and push gently and slightly inwards. If you hear or feel a "scratchy" type sound or feel, or if they dont move in freely, they are blown. And if that's the case, your amp could be damaged as well.
Most modern car amps have circuit protection and will shut down when they detect a load greater than they are used to so the amp MAY be ok. One way to test the amp is to hook another speaker to it, any speaker as a test is ok, and see if sound comes out. Make sure all power is off when connecting and disconnecting speakers!
Oct 17, 2007 | Jensen JX1200 Car Subwoofer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Paradigm Titan Speaker Logo
1,827 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
