Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
Does not drain all the way. I think it's the air
Does not drain all the way. I think it's the air gap. But where is it located and what does it look like?
    President:
  • 949 Answers
It could be the air gap. If you have one it is mounted on the sink next to the faucet. It is a cylinder about 3 inches high and about 1 inch in diameter (size of a small cup). It is usually stainless steel or chrome in color. You can pull the cap off of the air gap and carefully take the pieces out and clean any debris.
If this does not help the draining then you may have a restriction in the hose from the air gap to the drain, or the dishwasher to the air gap. You can look under the sink and follow the hoses.
Posted on May 01, 2010
Testimonial: "Excellent, most helpful!"
Water won't drain from either drawer
Do you have an air gap on the top of the sink? Pull off cover and check for debris. From the bottom of each DW to that air gap, hopefully the air gap is higher. Sometimes DW won't drain when they don't have a head to pump against. For instance, my DW is a regular model and from the pump to the air gap is about 3'. That is what ALL models are designed for.
Check for kinks in hose. Follow hose from under each unit and use your logical head thinking (your brain) to see if it gets to a point where it can drain. Does it go to air gap (mounted on sink) then drain by gravity to a wye shaped fitting under your sink? Does it go from the DW to the garbage disposal? To an open site drain?
Check all. And good luck with the units.
Dec 22, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
Bosch dishwasher SHU4000 problem starting, not draining
Drain problems are almost always going to be a clog. Disconnect the drain hose from the air gap vent at the sink top. Place a bucket under the hose and run the drain cycle. Unit should drain. If not, clog is either in drain hose or under the dishwasher's internal filter. Remove filter. Locate the item causing the clog and remove it. If nothing is found here, the problem will be in the air vent gap filter itself. Disconnect the other hose and remove the air vent gap from the sink. There's a small cap at the top of the filter. Press the clips in to remove the cap. Flush the unit with water or use a thin, long blade screwdriver to remove the debris.
Put it all back together and test again. You should be fine.
Mar 20, 2010 | Bosch SHU4006 Dishwasher
Just replaced our disposal and now our dishwasher will not drain. Any suggestions?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher will not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Dec 20, 2009 | Whirlpool Dishwashers
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Air gap valve leak for dishwasher
remove the entire drain hose from the air gap and be sure it is clear, also the dishwasher drain should be going to your disposal, if you chose to use the air gap it should be connected from d/w to air gap then to disposal, todays dishwashers dont need an air gap.
Sep 12, 2009 | Dishwashers
My frigidaire dishwasher routinely leaves some water in the bottom after it is finished washing and the dishes are always wet on the top
HI. check the following areas for faults.
1. Air gap / Drain hoses
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jul 19, 2009 | Dishwashers
After isntallation my dishwasher doesn't drain correctly. What could be the cause of that? Is that possible that conected incorrectly? or may be have to program it?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly. If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher. Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Jun 15, 2009 | Dishwashers
Does not drain. Water stays in the bottom.
Apr 13, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Maytag Model WU482 Dish washer completes cycle but dishes remain dirty and water is laying in the bottom.
Check the hoses and air gap for clogging. Air gap is located under the sink between housing seawar line and dishwasher hose.
If no help check/replace drain valve
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-drain-valve
if no help drain pump might be faulty.
Good Luck
Feb 25, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
167 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
