Question about HP Pavilion dv1000 Notebook
Will not re-boot
Pavilion will not re-boot after running out of battery. Tried removing battery and using AC power. No results. Reinstalled battery and fully charged it.
No results.
Repeats the welcome page. I tried:
resume as normal, prompt command, etc. No results.
Help
Thanks
Mark Major
    President:
  • 524 Answers
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
  • 1 more comment
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 09, 2010
    Figure A
    You'll then see a Recovery Console menu, like the one shown in Figure B. It displays the folder containing the operating system's files and prompts you to choose the operating system you want to log on to. Just press the menu number on the keyboard, and you'll be prompted to enter the Administrator's password. You'll then find yourself at the main Recovery Console prompt.
    Figure B
    #5: Fix a corrupt Boot.iniAs the Windows XP operating system begins to load, the Ntldr program refers to the Boot.ini file to determine where the operating system files reside and which options to enable as the operating system continues to load. So if there's a problem rooted in the Boot.ini file, it can render Windows XP incapable of booting correctly.
    If you suspect that Windows XP won't boot because Boot.ini has been corrupted, you can use the special Recovery Console version of the Bootcfg tool to fix it. Of course, you must first boot the system with the Windows XP CD and access the Recovery Console as described in #4.
    To use the Bootcfg tool, from the Recovery Console command prompt, type
    Bootcfg /parameter
    Where /parameter is one of these required parameters:
    • /Add--Scans the disk for all Windows installations and allows you to add any new ones to the Boot.ini file.
    • /Scan--Scans the disk for all Windows installations.
    • /List--Lists each entry in the Boot.ini file.
    • /Default--Sets the default operating system as the main boot entry.
    • /Rebuild--Completely re-creates the Boot.ini file. The user must confirm each step.
    • /Redirect--Allows the boot operation to be redirected to a specific port when using the Headless Administration feature. The Redirect parameter takes two parameters of its own, [Port Baudrate ] | [UseBiosSettings].
    • /Disableredirect--Disables the redirection.
    #6: Fix a corrupt partition boot sectorThe partition boot sector is a small section of the hard disk partition that contains information about the operating system's file system (NTFS or FAT32), as well as a very small machine language program that is crucial in assisting the operating system as it loads.
    If you suspect that Windows XP won't boot because the partition boot sector has been corrupted, you can use a special Recovery Console tool called Fixboot to fix it. Start by booting the system with the Windows XP CD and accessing the Recovery Console as described in #4.
    To use the Fixboot tool, from the Recovery Console command prompt, type
    Fixboot [drive]:
    Where [drive] is the letter of the drive to which you want to write a new partition boot sector.
    #7: Fix a corrupt master boot recordThe master boot record occupies the first sector on the hard disk and is responsible for initiating the Windows boot procedure. The master boot record contains the partition table for the disk as well as a small program called the master boot code, which is responsible for locating the active, or bootable, partition, in the partition table. Once this occurs, the partition boot sector takes over and begins loading Windows. If the master boot record is corrupt, the partition boot sector can't do its job and Windows won't boot.
    If you suspect Windows XP won't boot because the master boot record has been corrupted, you can use the Recovery Console tool Fixmbr to fix it. First, boot the system with the Windows XP CD and access the Recovery Console as described in #4.
    To use the Fixmbr tool, from the Recovery Console command prompt, type
    Fixmbr [device_name]
    Where [device_name] is the device pathname of the drive to which you want to write a new master boot record. For example, the device pathname format for a standard bootable drive C configuration would look like this:
    \Device\HardDisk0
    #8: Disable automatic restartWhen Windows XP encounters a fatal error, the default setting for handling such an error is to automatically reboot the system. If the error occurs while Windows XP is booting, the operating system will become stuck in a reboot cycle--rebooting over and over instead of starting up normally. In that case, you'll need to disable the option for automatically restarting on system failure.
    When Windows XP begins to boot up and you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options Menu. Then, select the Disable The Automatic Restart On System Failure item and press [Enter]. Now, Windows XP will hang up when it encounters the error and with any luck, it will display a stop message you can use to diagnose the problem.
    #9: Restore from a backupIf you can't seem to repair a Windows XP system that won't boot and you have a recent backup, you can restore the system from the backup media. The method you use to restore the system will depend on what backup utility you used, so you'll need to follow the utility's instructions on how to perform a restore operation.
    #10: Perform an in-place upgradeIf you can't repair a Windows XP system that won't boot and you don't have a recent backup, you can perform an in-place upgrade. Doing so reinstalls the operating system into the same folder, just as if you were upgrading from one version of Windows to another. An in-place upgrade will usually solve most, if not all, Windows boot problems.
    Performing a Windows XP in-place upgrade is pretty straightforward. To begin, insert the Windows XP CD into the drive, restart your system, and boot from the CD. Once the initial preparation is complete, you'll see the Windows XP Setup screen (shown earlier in Figure A). Press [Enter] to launch the Windows XP Setup procedure. In a moment, you'll see the License Agreement page and will need to press [F8] to acknowledge that you agree. Setup will then search the hard disk looking for a previous installation of Windows XP. When it finds the previous installation
My hp pavilion entertainment notebook pc keeps turning off i dont think its over heating it has to be something else ,, i turn it on and it will stay on for like 1 min or less and it will turn back off...
Reasons for that may be :
1. Bad battery - replace it.
2. Wrong power saving settings - you can set it according to your operating system's control pannel.
3. You may have a virus - if you run windows, try booting to safe mode by pressing F8 at the early boot stage and check if the computer still shuts down after 1 minute. If not, you need to run a virus checking software to try and find the malicious code that causes this.
4. overhearing
5. The BIOS may get the wrong temperature from the motherboard of the laptop. try to run an update for new software BIOS update from HP
Nov 08, 2010 | HP Pavilion dv7-1132nr Notebook PC
Hp pavilion dv6809wm has lights but wont postwhen i hit the power button the leds flash once and go off then the charging light comes on for a bit and thats all it does
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 19, 2010 | HP Pavilion dv6809wm Notebook
I have tried removing battery and reinstalling. i have reset with button and have used new ac adapter. I get power to laptop but all it will do is the power light blinks like in standby mode. it will not...
Please get back with the results.
Mar 19, 2010 | HP Compaq Presario 2135US Notebook
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Hey, i have a HP Pavilion dv6000 and since yesterday if i unplug the power cord it shuts off. i know that means the battery is not working but im not sure as to why. the battery meter is telling me that it...
Hi, when using the (AC Power Adapter), it is important that once the (Battery) is fully charge; to do one or the other. Stop! using the AC power, shutdown the computer, and unplug the AC power; use the battery (only), or remove the battery, and use (only) the AC power. Note: Using both power sources this can cause damage to the battery, by over charging, and possibly over heating the computer. Thanks paul7of9
Jan 05, 2010 | HP Pavilion dv6000z Notebook
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
HP Pavilion DV2700T PC Notebook - won't reboot.
go into bios next time it starts and turn off all power settings, same in control panel in windows and turn off sleepmode and hibernate.
Dec 01, 2009 | HP Pavilion DV2700T PC Notebook
My HP pavilion ze1250 powers up, the fan spins, but does nothing.
Is the ac adapter plugged in ? Have you tried to boot it up with removing the battery and using just the ac adapter? Sometimes you are drawing so much current from a bad battery that the computer won't start up at all.
Oct 09, 2009 | HP Pavilion ze1250 Notebook
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
Will not turn on, last time used, I turned it off manually?
Try this:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | HP Pavilion DV6500T Notebook
HP Pavilion dv1000 Notebook Logo
182 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
