Question about Kirby G5 Bagged Upright Vacuum
The drive lever came out. how hard is it to put back in
    Sergeant:
    Champion:
  • Kirby Expert
  • 357 Answers
Take it to a vac shop. you can't fix this yourself
Posted on May 01, 2010
Self propelled high speed
If by "lever" you mean the step on rocker pedal at the rear of the unit, then we're talking about the same thing. If not, then I have no idea what lever would move to "D" or "I". When the pedal is depressed on one side it puts the drive mechanism into gear, when it's depressed the other side it moves the drive mechanism out of gear. It's about that simple, unless the pedal is broken inside the drive box, then nothing happens either way, usually. The only way to tell if it's really broken is to try it in both directions, if there's no drive in either side then there's a problem in the box. You'll need to take it to a qualified repair shop, not everyone can repair these drive boxes.
Nov 11, 2013 | Kirby G4 Bagged Upright Vacuum
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
THE NEUTRAL/DRIVE LEVER HAS COME AWAY FROM THE HOOVER AND SOME OF THE INSIDES HAVE ALSO COME AWAY. I WOULD LIKE TO KNOW HOW TO PUT IT ALL BACK TOGETHER
I dismantled the cover, withdrew the gear drive assembly and found the bits that had come loose. The mechanism that selects neutral or drive had come away from its shaft. I simply put it all back together and tightened everything back up. Works a dream again.
Jan 10, 2010 | Kirby Heritage II Vacuum
The brushes spin fast until I put it down on the carpet
raise the bottom to level of the carpet , just so it hits, must be a lever in the back, its meant to sweep up debree to **** up, there is nothing yet to bring pile up
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Drive lever
that bracket is worn.....[ part number 557689 A ]...but is tricky to reassemble....
May 20, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Very hard to pump
It needs lubricating. Take it apart, clean it, then put machine oil on the moving parts and seals. If seals are damaged they need replacing. And, please only use it for target shooting.
Apr 30, 2009 | Vacuums
Tech drive lever fell off
could you supply me with a little more information? what lever are you talking about? the belt lift handle??
Aug 17, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
64 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
