Question about HP Inkjet 2600 Printer
The printer settings have not been changed (it is set on "Normal" print), but the printer is suddenly printing very very slowly. The final product is ok, but it takes forever to print a page. Any easy solution?
    Scholar:
  • 118 Answers
Another thought, if you have access to the photo on your computer, open it up and see if you can reduce the dpi level to a small file
go to the print page, check to see what the print format is: highest quality, best, normal, normal fast or fast print. this might be the solution too.
Posted on Apr 30, 2010
Why is my plotter suddenly printing slowly?
Sounds like it's been switched from "draft" to "quality" mode. There should be a menu option on the plotter to allow you to change that. You should be able to override that setting in your software, too.
May 22, 2015 | HP DESIGNJET T770 Printer
Why did my printing rate suddenly slow down to about 20 Why did my printing rate suddenly drop to about 20 % of normal
Check the print quality settings in the Printer Control Panel. If set to best and color it will slow printing considerably and use ink much quicker. Draft and B&W printing is usually fastest and sips ink compared to other modes.
Feb 20, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
PRINTS TO SLOW
Dear...
1> Use the properties section to check the speed settings in the driver and try again.
2> Printhead alignment checked.
3> Has someone changed the setting on the printer to Print "Best Quality" instead of normal?
4> Finally Full servicing Lexmark 2380 Plus Matrix Printer.
thanks...
Feb 15, 2013 | Lexmark 2380 Plus Matrix Printer
Hp deskjet printing very slowly all of a sudden
I am not familiar with this particular printer but here is what I would recommend.
Remove the printer from Windows,
reboot your computer, (a reboot must be done before reinstalling the printer driver)
Reinstall the printer in Windows.
The printer driver may have gotten corrupted. This is not uncommon.
There is also a chance that the power supply has gone bad. Most of these printers have the power supply as part of the cable, unlike a computer which has the power supply inside the computer. If you have another one of these model printers available, try swapping out the power cable.
May 05, 2011 | HP DeskJet 5652 InkJet Printer
HP P3015 suddenly printing very slowly - about a page a minute
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Feb 09, 2011 | HP P3015 Laser Printer
Slow printing
depends on what your printing, clarify more what your printing, text or a photo
if a photo, what is the dpi set at, if the file is multiple mb's then it will take longer
hope this helps
Apr 30, 2010 | HP Inkjet 2600 Printer
My HP 7280 printer has suddenly stoped printing on both sides
ONCE YOU HAVE THE DRIVERS INSTALLED DO THE FOLLOWING:
Go to START >> SETTINGS >> PRINTERS AND FAXES. Right click the printer in the PRINTERS AND FAXES window and go to PROPERTIES. Click the DEVICE SETTINGS tab Change the DUPLEX UNIT (FOR 2-SIDED PRINTING) to INSTALLED
Aug 06, 2009 | Office Equipment & Supplies
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP Inkjet 2600 Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
