Question about Microsoft Windows XP Home Edition
Xp updates... about 56
My computer is running on xp home edition and it has been going really slow from about 1 month after i bought it and the other day i went into add/remove programs and i saw 56+ xp security updates and updates, i looked on another computer and they werent there and i have never seen them on any other computer before. i looked at my storage space and it says i have 86% free space. i dont go onto the internet on it much but when i do, its for about a day and i update my antivirus norton and other things, but thats only about once every month or two, i dont think they are suppose to be there they all start with KB then 8 or 9 and then a series of numbers. is this what is causing my computer to be slow? and can i delete them?
  • Embem Mar 26, 2008
    thanks for all the suggestions.
    first suggestion to make programs load faster wont work, wither says its invalid or i cant change whats in the box.
    second suggestion, have gone through all the steps, still have to see if it works.
    third suggestion, dont understand what youre saying. is it: you save RD (is this a space?) /S/q in C:\Documents...
    fourth suggestion, these are all the programs that are in the start->run->msconfig->startup
    Says Setup
    ßnothing written
    Logitech Desktop Messenger
    Logitech SetPoint
    Microsoft office
  • 377 Answers
Hi dear
just trying this
This little tweak tends to work for most programs. If your program doesn't load properly just undo the change. For any program:
Right-click on the icon/shortcut you use to launch the program
Select properties
In the 'target' box, add ' /prefetch:1' at the end of the line.
Click "Ok"
Voila - your programs will now load faster.
This tweak reduces the time XP waits before automatically closing any running programs when you give it the command to shutdown.
Go to Start then select Run
Type 'Regedit' and click ok
Find 'HKEY_CURRENT_USER\Control Panel\Desktop\'
Select 'waittokillapptimeout'
Right click and select 'Modify'
Change the value to '1000'
Click 'OK'
Now select 'hungapptimeout'
Click 'OK'
Now find 'HKEY_USERS\.DEFAULT\Control Panel\Desktop'
Click 'OK'
Now find 'HKEY_LOCAL_MACHINE\System\currentcontrolset\Contr ol\'
Select 'waittokillservicetimeout'
Click 'OK'
This tweak works by creating a batch file to clear the temp and history folders everytime you shutdown so that your PC doesn't waste time checking these folders the next time it boots. It's quite simple to implement:
1. Open Notepad and create a new file with the following entries:
RD /S /q "C:\Documents and Settings\"username without quotes"\Local Settings\History"
RD /S /q "C:\Documents and Settings\Default User\Local Settings\History"
RD /S /q "D:\Temp\" <--"Deletes temp folder, type in the location of your temp folder"
2. Save the new as anything you like but it has to be a '.bat' file e.g. Fastboot.bat or deltemp.bat
3. Click 'Start' then 'Run'
4. Type in 'gpedit.msc' and hit 'ok'
5. Click on 'Computer Configuration' then 'Windows Settings'
6. Double-click on 'Scripts' and then on 'Shutdown'
7. Click 'Add' and find the batch file that you created and then press 'Ok'
Posted on Mar 25, 2008
  • Microsoft Master
  • 13,433 Answers
They are suposed to be there, note there is a checkbox in the windows witch reads, show updates.
  • Ekse Mar 25, 2008
    norton is known for slowing down pcs. If your paying for norton Id use it as long as it lasts and not review it. After it expires just delete norton and download avast home free.
    Avast home is a great program and I install it on most of the computer I service.
    If I where you Id just delete norton now and get a better program like avast.
    But its your choise.
    If you need more asistance, let me know. Good luck.
  • Ekse Mar 25, 2008
    I suggest agains trying hes suggestions.
    Thats a simple quick fix that will not last,
    to get the problem solved you need to solve
    the real issues behind it.
    start -> run -> msconfig -> startup
    remove the un needed programs like quicktime startup
    adobe spead up, update check, well you can post everything you see there here and il tell you witch ones you can remove safely.
    Other program to try is spybot
    run it to remove spyware.
Why does my comp. load web pages really slow, it just started this 1 week ago
Make sure to run a thorough virus scan.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 22, 2012 | Microsoft Windows XP Home Edition
Installed HD with OS(xp) to aspire sa80 But HD runs Very slow now
There is a program you can purchase (or it is more than likely available as a torrent) which will diagnose and fix almost any Hard Drive problem.
Have a read here
Sep 01, 2009 | Microsoft Windows XP Home Edition
Do not update my windows xp home edition sp3
1) if you dont want to update your pc any more you have to go to control panel ->classic view ->automatic updates -> turn off
2) if your pc dosent make any update you have to go to microsoft site and ask for updates
Apr 08, 2009 | Microsoft Windows XP Home Edition
Windows Update will not work
There must be something corrupt with windows update. Download this tool called dialafix & that will repair any problems with windows updates. after it runs through go to the windows update site & see if it lets you update this time.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Slow performance caused by unnecessary programs???
If your computer is running really slow, have you thought about cleaning it with windows disk cleaner? If your computer is otherwise working normally and you haven't loaded any programs that your want within the last couple of days you can also clean up your restore points and save loads of disk space. To do this go to Start>programs>accessories>system tools> Disk cleanup and tick the boxes that you want to clean for example tempory files etc then click on the tab that says more options and clean up system restore, it will still keep your most recent restore point. It will ask you if you are sure that you want to do this, click ok or yes. If you haven't done this before it may take a long time to open while it is compressing old files and determine how much space you will gain. But be patient, the longer it takes, the more space you gain because it is locating files that can be deleted. I hope this helps.
Nov 03, 2008 | Microsoft Windows XP Home Edition
My computer
Your PC isn't really old at 8 months. Most systems can be upgraded with more memory, a faster processor, larger hard drive, new hardware, and the list goes on. Are you running Windows XP? Windows Vista, is the latest OS from Microsoft, but I understand that XP is still supported. I guess the short answer would be to ask yourself: does it do what you need it to do? For example, I upgraded from my previous PC when I decided to do more stuff with DVD editing, and my old PC was a bit too slow to handle the higher speeds needed for editing video files to DVD's. You might as mentioned ealier in my post inquire about upgrading your PC instead. Figure out the costs, and then compare the costs with those of just buying a new PC. Then after comparing both options make your decision based on what you feel best meets your needs. PS: I still run Windows ME on an Intel Celeron 750 mhz laptop; for what I use it for it still works okay...BNG
Jun 26, 2008 | Packard Bell Computers & Internet
Windows XP Unusually Slow Startup
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
Computer running very slow
win xp required more then 256 mb ram
mcafee antivirus make system slow,
it take more ram
so u remove antivirus & also
go to run give msconfig
then remove start up items.
for more information call me +919985064600.
avast anti-virus is better it's do not make slower & also norton.
Mar 16, 2008 | Microsoft Windows XP Home Edition
Computer Lagging
need to clean it up
run cc cleaner download that tool online free then blow all dust out of yur case open it up blow it with big vac ok overheating add more fans if u can dl latest drivers u should be gooo d
Jan 23, 2008 | Microsoft Windows XP Home Edition
possible that the virtual memory is fragged. try disabling the VM then do a disk error check followed by a disk defrag then re-enable VM.
Sep 09, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
