Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer, and it has an DL F error code; I changed out the door latch. Unfortunately, the problem remains. What is the next logical change/step? Where is the relay that controls the door latch located?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Kenmore Elite He4 washing mashing. What is error code "dLF" or "FdL" and how do I fix it?
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load quiet pak that doesn't start and shows error code of F DL
Hi
Thanks
Rylee
Aug 21, 2010 | Kenmore Elite 45986 Front Load Washer
Dl F signal on kenmore elite front loading washer
Hi
Thanks for using FixYa. Error “dlf” means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 14, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite HE4T quietpak 9 washer. It has stopped the wash load with about 11 minutes left several times. It gives and error code DL then F alternating. The door remains locked and anytime...
The error you have is due to a failure in the door latch mechanism. There is a way to manually open the door if you are a little handy I can send you some instructions, it requires pulling the lower panel off (3 screws).
Let me know if you want me to help on this.
Phil
May 20, 2010 | Kenmore Elite HE4 Electric Dryer
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Received an error code dl f on my Kenmore Elite 45986. Replaced the locking mechanism and I am still receving the same error and results. It just clicks and gives this error code. Thanks "dl F" error code...
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 11, 2009 | Kenmore Washing Machines
Kenmore Elite Front Load washer with dl F error code.
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
You're gonna rate me..............?
Apr 09, 2009 | Kenmore Elite 45986 Front Load Washer
Problem
That is a door lock error code...check the latch and door strike for any damage, also try unplugging washer wait awhile and plug back in. If still get the f/dl than its time to replace either the door latch assembly or the main computer that controls it. Hope this helps - the doc
May 26, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE WASHER error (DL) then (F)
May 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
