Question about Poulan Pro Chain Saw 46cc 20"
How to reset chain brake has engine locked up after starting
    Habit-Forming:
    New Friend:
  • 100 Answers
The chain brake has a centrifugaul clutch and will not stop the engine from running. Grasp the forward most handle (Hand guard) and move it toward the bar nose (forward). Did it click? If yes the brake was released. Pull it aft until it clicks, it may require a little grunt at the rear extreme to latch. Wear gloves and attempt to rotate the chain. If the chain can be rotated the brake is released. Can you pull the starter cord? If not the brake is not the problem. good luck
Posted on Mar 31, 2012
    President:
  • 2,220 Answers
Starter Handle difficult to pull:
1. Remove the starter cover.
Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair or ordering any parts; if yes continue.
Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
Leave the ignition off, set the valve and pull the starter.
Pull gently to release the valve. Is there a difference in the effort required?
If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
  • dontbother10
    dontbother10 Apr 30, 2010
    If the starter will not turn yopu cannot perform #2. Continue with 3. I think that is where teh problem lies.
My Poulan Pro PP5020AV chainsaw brake is engaged & will not disengage. The chain continues to rotate. Any suggestions on how to fix?
If the chain continues to rotate than the chain brake IS Disengaged. When the chain brake is Engaged, the chain is locked. Any problems with the inbuilt safety features needs fixing by a Poulan engineer.
Sep 29, 2016 | Poulan Garden
Tip
How to get the chain brake reset so ou can get the sidecover back on
If you have removed the sideplate on your chainsaw with the chain brake in the locked position, you will have a very hard time getting it back on without destroying the brake band. If you have done this try this solution. First remove the bar and chain fronm the saw, then start putting the side cover on, use one of the nuts on the front screw.As it comes in contact with the ratcheting part of the hand break make sure you push the chain brake handle forward while tightening the front nut I mentioned. when the nut is snug, pull the brake handle back to reset the brake, You will hear it click into place. then remove the side cover and re install the bar and chain. your good to go/
on Dec 15, 2009 | Garden
Engine starts but when I pull the lever to start the chain it's stuck and won't power the chain
you may have to pull it down and check the operation of the safety brake
the lever is an over center device which when pushed forward locks the clutch action to the chain and brakes the chain to stop it from moving
Mar 28, 2016 | Garden
Will start but goes dead when attempting to disingage brake
How To Reset Husqvarna Chain Brake ' Fix Stuck or Locked ...
? 1:58
www.youtube.com/watch?v=JiIhO0mDuZc
Mar 7, 2013 - Uploaded by vminnovations
Learn how to disengage the chain brake and reset the chainbrake if the clutch ... Amazing - I was going crazy trying to find out how to fix this without ... Amen. this helped out big time... borrowed a chain saw but couldn't fix it ...
Sep 14, 2015 | Garden
Poulan gas hand saw is locked reset handle will
Are you referring to the chain brake handle or the handle you pull to start the saw? To reset the chain brake handle, pull it back towards the rear of the saw, this may take some force. If the starter grip or handle will not pull out then your saw may be seized or something is wrong with the starter its self.
Oct 19, 2014 | Garden
I have difficulty starting my Gardenline 49.3cc chainsaw. Please let me know what the correct starting proceedure is.
Genral starting procedure on a chain saw is as follows, put fresh fuel into the fuel tank, top up the chain oil tank,switch the ignition on, if the saw has a half throttle position on the trigger lock this, if the saw has a primer depress this as many times as it takes to 3/4 fill the bulb, pull the choke fully out, if it has a deco valve push this in, now place the saw on the ground with the chain brake on and crank the engine ( always have the saw body between you and the cutter bar,NO left hand starting, NO drop starting ) the engine will only fire once on full choke, do not continue to crank engine after the first fire or you will flood the engine, push the choke back in, crank the engine until it fires up and runs,release the chain brake and blip the throttle to release the half throttle device.
Jan 22, 2011 | Garden
Husqvarna chainsaw 235e starts but the chain won't move. Maybe the brake is stuck??
Does the brake seem to 'snap-over' like it should? Pull it back to release position, and remove the drive cover. Check the entire brake for debris accumulation or bent/damaged brake band. Check the chain to see if it is being oiled. Remove the bar/chain and clean the entire assembly, particularly the small oil passages in the drive end of the bar. Start the engine and watch for oil oozing out of the small side port where the bar fits. If ok, reassemble the bar/chain. If no oil comes out, investigate the oil pump, lines, and filter/valve in the oil tank. Mount the side cover, but leave the fasteners finger tight. (The chain teeth cut toward you on the bottom run) Tighten the chain until the lower run comes up to the bar, but can still be turned by hand. Tighten the fasteners and recheck the tension. Trip the chain brake and make sure it locks the chain, then release it and make sure it turns freely. Check the chain oiling by running the bar tip at speed near some cardboard--it should leave a thin line of oil on the board. Hope this helps!
Jun 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro Chain Saw 46cc 20" Logo
358 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
