Question about Frigidaire Freezers
E8 code on display - Frigidaire Freezers
    Problem Solver:
  • 5 Answers
E8 code on kenmore freezer
Posted on Aug 18, 2011
Have Frigedare upright freezer that is displaying H9code. What does this mean?
The H9 Code doesn't exist. I think your display is faulty and is showing - 19'C which is a good temperature to an optimum of minus 18'C.
Try turning it off for 2 minutes and then power it back on.
Frigidare freezer H9 code Google Search
May 05, 2018 | Freezers
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Error code E8
Check wiring to evaporatorsensor. If correct, replace sensor. That will require a professional's attention.
Jul 29, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Frost free fridge/freezer
that is an error code call manuf. for solution
Dec 06, 2007 | Freezers
Freezers Logo
366 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
