Question about Mackie SRM-450 System
My speaker made a very loud noise and stopped working. It might have been a reaction to mics under my acoustic to which it was pointed. The mics belong to a PR1 acoustic piano recorder which was in use at the time.
  • 1,284 Answers
Hi, you probably have a situation whereby speaker amplifier chip may leaky or damage. You need to change it.
Take care
Posted on Apr 30, 2010
High frequency noise form my 7.1 surround sound system
Is the microphone live? If so, what you're getting is called "acoustic feedback". Any room sound gets in the mic, gets amplified, comes out the speakers, and then gets picked up by the mic again. Louder and louder until you get to the maximum your system can do.
The solution is to turn it down. . . until it stops.
May 13, 2015 | Acesonic HKR-710 340-Watt 7.1 Surround...
Bose Quiuet Comfort 3, clicks in one ear when first put on. Loud clicking coming from speaker. Any ideas?
Hi. may be a vibration in the microphone hollow. Put some cotton wad under the mic capsule.
Jan 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Woofer maiking a loud noise
be more specific, what type of noise? Humming noise or cracking noise or pop noise? can you still hear noise without signal input line connected?
Mar 05, 2012 | Acoustic Research 308 HO Speaker
My subwoover is giving me large feedback, like high pitched noises
lower the mic volume or don't be so close to the your speakers when using the mic. or turn off your mic. thanks and have a nice day.
Apr 30, 2011 | Cyber Acoustics CA3602 2 Speakers
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email rushi_jky@yahoo.com
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Mackie SRM-450 System Logo
65 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
