Question about Zebra QL 420 Plus Thermal Label Printer
Client Access printer configuration for ZM400. Prints okay from the PC however prints sent down from AS/400 won't print.
    Scholar:
  • 185 Answers
You will need to build a driver for the AS400 to handle ZPL, similar to Unix drivers
Posted on May 04, 2010
Prints blank pages and gibberish
You may have to shut down the printer completely, including disconnection of power. When you reapply power, the printer should be indicating it is offline so you will have to put it online again.
Dec 04, 2013 | HP Laserjet Pro Cp1525n Color Printer...
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
I have 2 ZM400 printers one is workign fine and the other isn't the printer only prints partial data on the right side. We have matched the setup configuration fomr the one to the other with no...
The ZM400 is a thermal printer. Try cleaning the thermal print head. And also ensure that no cut paper slips have lodged themselves against the thermal print head.
Jun 09, 2011 | Computers & Internet
When we print to Xerox Phaser 6180 the print job prints the first page from tray 2 and then wants tray 1 loaded with paper to finish the print job. The paper in tray 2 is 8.5 x 11 the same that is...
I suspect the machine is on a network and the driver is installed on the server. Your workstations driver properties are probably not the same. i have seen this problem quite a few times and its always been down to configuration and not a fault of the printer. Basically a printer prints what it is sent and to where it is sent.
Good luck
Jun 01, 2011 | Office Equipment & Supplies
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Tally T2030 matrix printer prints 2 copies of everything when only 1 sent? its attached to a as400. All help is much appreciated.
On the device config for the printer on the AS\400 it is possibly configured to print 2 copies.
wrkcfgsts *dev printername
check and see if it is configured to print 2
Jun 18, 2009 | Tally Serial Matrix T2030 Printer
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Zebra QL 420 Plus Thermal Label Printer Logo
520 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
