Question about Sharp AL 1631 Copier
How do i check copy count? - Sharp AL 1631 Copier
  • 1,110 Answers
Hold down the "C" key for a few seconds. The page count will be displayed in 2 sets of numbers. Such as 026 then 003. This would indicate 26,003 copies. The machine must be in the ready to copy state.
Thank you for using Fixya.
Posted on May 01, 2010
I bought used mpc4500. Counter counts 2 clicks for 11 x 17 copy. Ricoh service tells me there is no way to reverse that setting back to just one click per 11 x 17. Is this true?
doubtful its true,but it is a standard practice to set up the machine to count 11 by 17 as 2 clicks because it is 2 pieces of 8.5 by 11 which are counted as 1 .... GET IT ?
Jan 25, 2013 | Office Equipment & Supplies
Is there a way to find out the total copy count for the printer?
You can get the copy count for the MF6550 by using the following procedure:
- Press Additional Functions
- Press 2
- Press 8
- Press Additional Functions again.
- Scroll down through the options. There will be an option for Counter -- select it and the copy count will be displayed on the screen.
For page count and configuration page instructions on other copiers, printers, and fax machines, visit the How to Print Configuration Pages website.
Jun 15, 2011 | Canon imageCLASS MF6550 Monochrome Laser...
Warning light is ON for drum AL1340 does it have to be replaced or does it need cleaning?
This means that the default set meter count is due and sometimes the copier stops at this level if it is set so. Please check if the copies are coming out clean and clear as sometimes it may display drum sign with as low count as 5000 copies if set so whereas it can even reach 50,000 copies or higher. If okay , just do not replace it and concentrate on how to clear it. Key in this ( C Auto C Auto) in this order and enter (24 press copy key, enter 7 press copy key). This clears the drum sign and you are relieved.
Jan 27, 2011 | Sharp Office Equipment & Supplies
My printer is saying "Check
Try this procedure:
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Jan 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
How to get a copy count on a ricoh 7200 printer
To view the copy count, you'll have to print a config page. Press Menu, then scroll down until you see List/Test Print and press OK. Choose the Config Page option, and you'll get a page or two of information, with the copy count (broken into black and white and color) listed near the top of the first page.
Jul 20, 2010 | Ricoh Aficio CL7200 Laser Printer
Can the Canon Imagerunner 3030 count/sort sheets of paper out for you?
please, the count you want is copies made or you want the machine count the originals ??
The machine count 1 copie for A4 (LGL) and 2 copies for A3, called double count.
Nov 20, 2009 | Canon Office Equipment & Supplies
We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Sharp AL 1631 Copier Logo
207 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
