Question about Mtd 22" Yard Machine Push Mower
My yard machine push mower model number 11a08mb000 is smoking really bad but it is still running and when i push the choke down it shuts off. why would it be smoking and why when i push the choke down the mower shuts off?
  • 61 Answers
The smoking is probley from bad or wore rings. The choke problem is from a clugged carberator.
Posted on May 09, 2010
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
Engine only runs with choke on. Blue smoke comes out and engine runs rough or not at all
sounds like you have a bad Ring on the Piston or a blown head possibly. Blue smoke means Oil is getting into the combustion chamber. Full choke means you have to give this 'broken' engine a lot of gas to compensate for it's problem.
Do you change the oil at least once a year? Filthy oil or a lack of oil will kill an engine
Aug 06, 2012 | Yard Man Garden
22 in Yard Maching push mower. Used 1 1/2 seasons. Bought new. Was running great. Shut it off for about 5 min. Upon restarting, it ran very uneven when the choke was disengaged. You could see it...
First remove spark plug wire and check that it isn't full of grass around the blade. ///Then go to filter which is on top of carburator and clean with varsol. Squeeze excess varsol out and then add few drops of oil across the top and replace back on top of carburator.///If it still acts up, then add a gas pressurative to the fuel and let it run through..let us know how you make out.
Sep 22, 2010 | Mtd 22" Yard Machine Push Mower
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
YARD MACHINE MOWER NOT A YEAR OLD YET AND IT CRUDDIES UP EACH NEW SPARK PLUG AND SMOKES, NOT RUNNING WELL. ITS RUNS REAL FAST AND THEN REAL SLOW, SPUTTERS. I HAVE ALWAYS KEPT AIR FILTER CLEAN AND OIL...
Return the mower if possible for warranty repair or call MTD with the issue. MTD mowers typically are good quality and should run like new for a long time with proper care. Depot may give you a 1-800 number instead of customer service so before you load up the mower talk to them. It does sound like a bad valve seat or rings either one is not typical wear and tear.
Jun 07, 2010 | Mtd 22" Yard Machine Push Mower
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Jul 14, 2009 | Mtd 22" Yard Machine Push Mower
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Yard machine 139cc will only run short time with choke
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Feb 08, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
274 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
