Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf840, what does this mean F-05
  • Hotpoint Master
  • 3,463 Answers
F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Posted on May 01, 2010
Hotpoint wf840 fault (F-02) please help do u know what tis means?
try checking motor - module connections -brush - tacho on the motor
Nov 04, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
My washing machine is giving me F-05 on the screen, it will not empty after the load has finished, please help (Ultima WF840)
Sound like your drain pump is blocked. Tilt the machine as far back as you can to access underneath. The drain pump is located at the rear corner. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
My washer (hotpoint ultra silent wf840) is displaying f-08 on it's digital display, can anyone help please.
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Feb 23, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have a hotpoint wf840 washing machine (6 years old) and the wash program will not complete the drum turns but will not advance to the end or spin and on the front facia it states f-08 what does tis mean
F08 means you have a heater fault and in this case because the water isnt getting hot the program wont advance. Check out the heater and related wiring. If you dont already know the heater is at the rear of the machine. For more information about error codes go to www.selfix-uk.co.uk
Jan 31, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Washing maching displaying a code F- 05 and door wont open. Looks like it hasn't spun either. What is going on?
Hello,An F-05 means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Thanks
May 23, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF860 Front Load Washer Logo
331 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
