Question about Creative Labs Gigaworks S750 Computer Speakers
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my amp is gone?
    Scholar:
  • 83 Answers
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Posted on Apr 30, 2010
Sound drivers samsung laptop
Sounds like a problem in the setup.
Oct 18, 2013 | Audio Players & Recorders
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
How do change the woofer in theis speaker
are they still under warranty?
Worth checking into ... JBL has a good warranty program for this series and local authorized repair centers ... if you are under warranty you could have a fix for free in about a week ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 22, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How To Remove JBL Model L46 Woofer
Get a metal 1" wide thin spatula and tap it in between the speaker and the cabinet. The 117 woofer has a large flat side. Work your way around the frame and gently pry it up. Good luck. Pointblank
Dec 09, 2009 | JBL Audio Players & Recorders
I am using Jbl 1200w woofer
actually i want tat d voice effect should b lik a surround system nd for tat i hv 2 increase d volume...by increasing the volume it gives a wonderful effect outside but m nt gettin ane vibrations inside ma car nd moreover i think thr is sm problem with vocals..shud i go 4 sm tweeters so tat sm clarity effect can b increased?..
Apr 09, 2009 | JBL BassPro Car Subwoofer
Connection system
hi,
connect satelite speakers to the amplifier and connect signal cable (RC pin) to the woofer from amplifer ie subwoofer out from amp. ok na.
-kanny
kanny-sounds.blogspot.com
Dec 15, 2008 | JBL 5.1-Channel Home Theater Speaker...
Jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Nov 02, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Creative Labs Gigaworks S750 Computer Speakers Logo
436 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
