Question about RCA DRC8335
DRC8335 DVD/VCR combo is stuck on HELLO - RCA DRC8335
  • jmarquardt Apr 30, 2010
    It is stuck on HELLO--nothing works.
    Everything is frozen. None of the buttons work. We have tried the methods suggested by the RCA people (not very helpful, I must say). What about that little capacitor (c226)I keep reading about that is underpowered and explodes (esp. if there is too much heat)?
  • 10,515 Answers
I would like to Share Few Details with You. This is a Common Error on this Model. Repair would not make any Sense, as the Cost of Repair is Quite High Relatively to the Cost of the New one.
So, if you Could get this Fixed. That would be Perfect unless Seek for a New Player.
Now,
First of ALL, try to Reset it. Unplug it for Few Minutes, say 30 Minutes and then Turn it ON. If the Problem Persists, this is an Internal Fault.
You need to Open the Player to get it Fixed. Other thing, i have seen, that this Error Could be Due to Lens. If the Player is Quite Old, Lens could be at Fault. Buy a Cleaning Kit from Radio Shack and use it. Sometimes, it works like Wonder.
If that would not work, Open the Player and look for Lens. I could give you a Picture of Lens.To clean manually unplug from wall and leave two minutes.Remove cover identify the lens as a small round glass lens in the DVD tray assembly.Clean with the glass lens with a cotton bud or similar, use a small amount of isopropyl alcohol or do the clean dry, any other cleaning product could damage the unit.Remove any foreign objects in the unit.Reassemble and test.
DRC8335 DVD/VCR combo is stuck - d2e99cb.jpg
If no luck then you will need a new laser assembly I'm afraid.
Now, regarding Caps. Yes, it could be another Problem. When you Open the Player, you would see Caps like :-
If you see, Cylindrical Type Components, all those are Caps. There might be chance that any one of these could be Leaked / Bulged / Swelled. Make sure that there is no Cold Solder Joint and there is no other Broken Component on the Board.
If you find anything Swelled / Leaked / Bulged, you could De Solder and Re Solder the New Caps. The caps could be easily available in the Market. You could buy it Online or you could go to Radio Shack, Fry's.Make sure to Buy a Similar one. I have seen , if you buy a Low Quality Cap, it could again Swelled or Blown.Usually Bad Caps have Ammonia Kind of Odor.
I hope that the above information would be useful for you to Resolve the Problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 01, 2010
  • RCA Master
  • 19,396 Answers
That means that the unit is not passing the initial POST test, or it is getting stuck at the end of the post, when reading a disk inside the unit.
Ensure that there is no disk inside the unit. Try pressing repeatedly the eject button while starting the unit at the same time.
Try disconnecting power cord for two minutes.
If all that does not work, then the problem is likely a firmware failure.
Firmware for the DRC8335 is not available online. In that case the only thing to do is contacting RCA and asking if a software or firmware release for this unit is available.
To get support from RCA you need to start a support account, then to create an incident. Here how to proceed:
Posted on Apr 30, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the lens is not reading the disc. To start with try running a lens cleaning disc, if that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. If still the issue is not resolved then the lens should be replaced however, replacing a lens will cost you around $75 and a new one will cost you around $50. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2 Suggested Answers
SOURCE: My combo DVD/VCR DRC8335 will only display HELLO
I have an rca drc8335 vcr/dvd player that is locked. I have the code to unlock it, but don't know where to post the code. Can you help me?
Posted on Jan 03, 2010
I have a RCA DVD/VCR combo DRC8335. I tried to put a VHS in it and it won't take it. It is like it is not even reading it. THe VCR power is on but nothing is happening! Now the VCR door is stuck open! ...
The loading basket is defective, or the loading gears are out of alignment. Check for broken gears, belts, and a twisted basket after removing the top cover. If speed is an issue you may need to take it to a technician to see if it can be salvaged.
Apr 30, 2011 | RCA DRC8335
I need a manual for this product. Any chance I can download one? RCA DRC8300N DVD Recorder / VCR Combo
I see RCA no longer has any manuals for that unit. But, is this the exact model number? I mean like I have an RCA DRC8335 VCR/DVD recorder, so I am wondering if it is similar? If so I could work out something for you. Email me at jmsekola@citizens-tel.net if you think I can help with my manual.
Jan 01, 2010 | RCA DRC8300N DVD Recorder/VCR
My combo DVD/VCR DRC8335 will only display HELLO and not respond to the remote or buttons on the face. I have tried the troubleshooting portion of the manual and need help.
Dec 12, 2009 | RCA DRC8300N DVD Recorder/VCR
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
Problem with DVD/VCR RCA DRC8335
More than likely the DVD drive in your unit is bad.
Feb 27, 2009 | RCA DRC8320 DVD Recorder/VCR
Unit says hello
This problem is normally caused by a dvd player with a dirty lens that it cannot read or detect a dvd in the player. At the same time if this is a dvd/vcr combo a vcr that will not load or is stuck can cause the problem. These can be checked by taking the screws off the unit and taking a look at the position of the dvd laser lens or the vcr position to see if it is in the fully eject position. The part that holds the laser lens to read the dvds can be moved manually back and forth to dislodge it from a stuck position with the power off. Depending on how long it sat around it could just be stuck. You see when you first turn the power on to the unit initially or try to eject a dvd, it will cycle through and try to read a dvd even though there is not one there on power up. If that assembly that moves the lens to read the dvd cannot move, it will cycle off and turn itself off even though you try to reset it with the power button.
A transistor on the power supply can also cause this problem but without taking signal and voltage measurements it would be difficult to pinpoint the exact one. So try moving the laser lens assembly manually and then turn it back on. Let me know. Good luck.
Jan 15, 2009 | RCA DRC8335
RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 13, 2008 | RCA DRC8335
RCA DRC8335: shows "padlock" symbol
Mark. Use the emergency factory-set master password 9688 to cancel and remove any previously owner set parental control password. Refer to page 26 of the User Manual if needed.
RCA DRC8335 User Manual (PDF 1.92mb) <---click here to begin immediate download
Please rename the ugly unreadable (encrypted filename) back to the original as highlighted above in blue, once the download has completed. mikeadams110@yahoo
Aug 15, 2008 | RCA DRC8335
VCR won't accept tapes
VHS VCRs are not being produced in very large quantities any more. You may still be able to find a combo unit DVD/VCR.
The problem may be a belt or gear, or it may be that the tray is damaged. Only a tech can tell you, but there's little point in repairing these. I know Wal-Mart still sells them...
Ken.
Aug 07, 2008 | RCA DRC8335
RCA DVD RECORDER AND VCR COMBO
Your question is not clear?Are you asking a blank dvd on a home line dvd recorder/player or a blank dvd from a computer or a blank dvd in a dvd camcorder?
Jan 06, 2008 | RCA DRC8335
RCA DRC8335 Logo
635 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
