Question about Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
I have an el-14 patriot --
It will not stay running----feels like the trigger is not working-----Is this a simple fix or not?
  • dontbother10
    dontbother10 May 11, 2010
    Is this a Poulan? Is it electric? The headings are often wrong, And I need clarification from you to continue please. Below. Thanks. Make, model and serial are always a good idea. In the body removes all question.
How do I write a essa about what does patriotism me to me
Well only you can answer that. What does it mean to you? Are you proud of your country, do you feel pride when you see the flag? Do you feel the loss of those who died to give you the freedom you enjoy? Write down what you feel and that is what it means to feel patriotic.
Oct 16, 2013 | American Flag T-Shirt - Patriotism
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
No prende tablero de jeep
tengo una jeep patriot 2009, no prende el tablero ni las luces interiores, tampoco funciona el claxon ni los limpia parabrisas. el control remoto no abre las puertas.. que pasara?
Jun 03, 2012 | 1997 Jeep Cherokee
Model #55-6848-8 14 inch metal cut off saw. purchased at Canadian tire corp. this saw sits for long periods of time in between uses.it is still in brand new condition. the saw worked a-1 for the first two...
It is simple to fix this. Take out the switch and open the switch. The contacts are stuck. It takes little to open the contacts. You may need to smooth contacts off with emery paper. It need to do the same. It works fine after. The difficult thing is to open the handle and get the switch out.
Apr 26, 2011 | RTO UST 14-inch Metal Cut-off Saw
Cuantos litros de aceite y que tipo de aceite lleva una jeep patriot 2008 4 cilindros gasolina y donde se encuentra su filtro de aceite y gasolina
hola que tal el filtro de gasolina lo traen arriba de una tolva que se encuentra exactamente por las ruedas delanteras ( abajo del motor) quitas esa tolva y es de lo mas facil cambiar el filtro y el aceite,, el de gasolina si esta un poco mas complicado pues esta dentro del tanque. lleva aceite del que quieras un 20w50 estaria bien depende de que kilometraje lleve pero mejor ponle un sintentico...
Sep 18, 2010 | 2008 Jeep Patriot
I can not get my grass trimer Bolens Bl100 to keep running when I press the trigger down it dies
clean the carburetor. if the diaphras in the carb feel stiff id get a carb kit. also check the fuel filter as well.
May 03, 2010 | Black & Decker 14" Grass Hog Xp...
Brake lights not working
RockAuto has brake light switches for your car ranging in price from $14 to $30. 2006 NISSAN SENTRA 1 8L L4 Brake Light Switch RockAuto
Jun 07, 2017 | 2006 Nissan Sentra
Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw Logo
108 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
