Question about Western Digital Passport 120GB External USB 2.0 Portable WDXML1200UExx Hard Drive
WD portable hard drives not recognized
My WD portable hard drives are no longer recognized by my computer.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer says "USB device not recognized" when
You are likely missing the drivers. If you really need to get it open, plug it in, find the drive, right click and select explore. This MIGHT work; i'm not entirely sure.
Feb 09, 2011 | Western Digital WD Passport 250GB Portable...
My computer can no longer recognize my WDBAAU0015HBK, western digital portable hardrive. I have tried everything swapping computers, USB cable, etc. All I want now is to return this hardrive (RMA) to WD...
DID YOU TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT, ENLARGE THE PAGE , LOOK FOR YOUR DRIVE, RIGHT CLICK YOUR DRIVE AND MARK PARTITION AS ACTIVE. ....HOPE THIS HELPS.......JEFFXC
Feb 08, 2011 | Western Digital WD Elements Desktop...
Our 2002 Gateway computer will not recognize a USB
Go to the following website listed below and download the file you need. It needs to be placed in the C:Windowsinf directory (not in any folder).
http://www.infdump.com/download-inf-file
Nov 15, 2009 | Western Digital WD Passport 250GB Portable...
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
WD Elements external hard drive not recognized/can't be found
ur vista version has a problem with usb portable devices so either u have to upgrade ur vista to the latest on or install windows 7 or down grade ur laptop and install windows xp
Jul 27, 2009 | Computers & Internet
Dvr no longer recognizes hard drive
Try switching around some wires.
If that doesn't work then it might be damaged.
I suggest plug it into another computer to see if it still works. Find out if it's the hard drive or the computer.
Jul 10, 2009 | Computers & Internet
My computer doesn't recognize my wd hardrive when i plug it in
its problum with the cable or with your Operating System your are using,,, try on different USB Ports the pc have...
good luck
shafky
Jun 26, 2009 | Western Digital WD Passport 250GB Portable...
My computer will not recognize my 160GB WD My Passport Essential portable hard drive.
if you have any software that you installed with the drive try uninstalling it, i had the same trouble on my 500gb WD. after you have uninstalled the software, restart your computer and reconnect the drive. hopefully it will recognise the drive as it did with mine.
Jun 16, 2009 | Western Digital My Book Essential Edition...
My portable hard drive is not recognized by my Mac G4 power book
You have to run mac tools that is on that hard drive prior to plugging it in.
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
Computers & Internet Logo
143 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
