Question about Apple iPhone 3G
IPhone slider won't slide all the way across
My iPhone 3G slider (slide to unlock, turn off etc) won't slide all the way across - it gets about half way then slides back. The screen isn't broken in any area - I can press 'cancel' after holding down the power button, and having opened up my phone the digitzer also seems fine. Have tried a hard reset and a full restore.
Would appreciate either a solution for the problem itself or a way to bypass the 'slide to unlock' screen.
Thanks!
I'm having the same issue, have you found any solution?
Posted on May 19, 2010
Slide finger across wont open
Hi Anonymous,
if sliding your finger across the "slide to unlock" bar won't unlock your iPhone it's possible that your touch screen is (partially) broken.
Try a reboot first: Hold the Power-Button until the "Power off" slider appears. Hopefully you can slide that. If not hold Power and Home-Button for approx. 10 seconds until the phone is off.
If after starting your phone again you can't "slide to unlock" you should see to get a screen replacement.
Mar 04, 2015 | Apple iPhone 4 Black Smartphone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
My iphone 3gs shut off and won't turn on... tried rebooting it but saw nothing. How long should I hold the "Home" button and the "Power" button?? If this doesn't work, what should I do??Please help...
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 06, 2010 | Apple iPhone 3G
My phone is locked up and wont turn off. how do i turn it off to reset?
Oct 05, 2010 | Apple iPhone 3G
My phone will not ring, it is not on any silent modes
Sep 30, 2010 | Apple iPhone 3G
IPhone wont turn off
Unlock the screen.
Press the button on the top of the phone and hold it down.
In approximately 5 seconds a "slide to power off" message should appear.
Slide the slider and power off the phone.
If this does not work take it to an Apple or AT&T store.
If this helps please vote for my solution.
Jun 24, 2010 | Apple iPhone 3G Black Smartphone
The bottom slider wont slide to unlock on iphone i tried by resetting it but to no avail?
you have a broken digitizer my freind, go to youtube and serach for 3g/3gs digitizer replacement, they will tell you how to do it and where to buy one. good luck
May 05, 2010 | Apple iPhone Smartphone
My iphone screen won't work
iPhone may exhibit a problem where it does not respond to any button, switch, or touchscreen input.
  1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPhone remains unresponsive after trying the above steps or if it is in a different state, such as showing a persistent Apple logo on the display, try resetting the device:
Before following the steps you need to take a backup of your iphone
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
Oct 31, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
1,142 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
