Question about Archos 404 Digital Media Player
Usb cable for archos 404
When i plug the cable in my pc makes the noise that a usb has been plugged in but nothing comes up on the my compter screen
  • GEE37 Apr 28, 2008
    thanks very much for the help but it turned out to be a loose wire in the usb cable,thank you though
I suspect it is because the drive letter it is attaching itself to on your PC is already taken. When you stop the device to remove the useb cable, it will show you what drive letter it is attaching itself to. In my computer, check that this drive is already taken and disconect. Now try re connecting your Archos and it shoud appear in My Computer. Hope this helps
Posted on Apr 25, 2008
Check device manager and verify that it is showing up in there. Also, have you checked My Computer?
Posted on Apr 18, 2008
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
May 02, 2008 | Archos 404 Digital Media Player
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
Mar 01, 2008 | Archos 404 Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
ARCHOS 404.. new.. won't turn on or charge
Leave it to charge for 2 hours just in case there isn't enough power for it to boot up properly until it has an initial charge.
Dec 24, 2007 | Archos 404 Digital Media Player
Usb cable semi-working...
Wiggle the cable at the device to get a good connection. Does your USB port support other devices? Plug into another port and see if this solves the problem.
Oct 18, 2007 | Archos 404 Digital Media Player
Archos 404 Digital Media Player Logo
269 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
