Question about Linksys Wireless-G WRT54GS Router (e125894)
I can't get my new Nintendo Wii to access myr router
I can't get my new Nintendo Wii to access my linksys wrt54gs wireless router..I get error code 52230...what do I do?
  • 2,260 Answers
According to Nintendo web site, it happen because of firewall on the router.
You will need to disable to firewall on the router.
Open the set up page of the router. Disable the firewall. You will see it under security tab.
Reduce the MTU to 1365.
Also you can open some ports for the WII.
Click Here for more information about the routers and network
Posted on Apr 30, 2010
Wii error message 51030
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over.
visit the CBR Tech Solutions
Jan 12, 2014 | Netflix
How do i set up a wifi conection from my wii to my modem please
Nintendo's wireless connection will only support WEP security. So before connecting it wirelessly, check your wireless router/wireless access point and make sure that IF it has a wireless security configured on it, it's on WEP. So the wireless security should either be Disabled or at WEP. You can check these options on the router's Web UI. If you have a Linksys router, I could help you with it.
follow these steps:
1. Setup Screen > tap "Nintendo Wi-Fi Settings".
2. Select a "Connection slot".
3. Tap "Search for an Access Point. (This will open a list of wireless networks detected.)
4. Select your network (or any network you want to connect to) and connect to it. It will ask your for the network key or WEP key if you have it setup on the router.
Nov 13, 2011 | Nintendo Wii Console
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
I have been trying to connect my Wii to my Linksys wireless in my home and every time I try, I get the error code of 51330 with a mention of being unable to connect to the internet. What can I do to fix...
A. Do you have the SSID for your Linksys router as just "linksys"? That name is so common that someone nearby might have set up a new router and left it the same name as well... and your Wii is trying to connect to THEIR "linksys" instead of yours. Try changing the name broadcast by your router to something else, then try connecting using that new name.
B. Be sure you are typing in the WEP or WPA passphrase correctly, it is SO easy to mess up one simple letter in the code and nothing will work. I've gotten dozens of service calls for iPods and games where the customer said their code didn't work, but worked for me when I got there. I know, it's frustrating, just be SURE you have the code 100% correct.
Other reading material from Nintendo is below:
Wii error code 51330 It is unlikely that your Wii console needs any type of repair, as according to the Nintendo Error Code Lookup, the 51330 error code is "usually indicates a problem relating to wireless security."
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  8. If you are still receiving this error code, please click here for assistance.
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one of the service representatives will do some over the phone troubleshooting to determine exactly what is causing this and then talk you through any needed steps to correct it.
May 25, 2011 | Computers & Internet
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Trouble connecting to internet says error code 51032 it says it cannot find access server I have checked my ssid and shared key and they are correct
Sorry to hear you are having problems with your internet on your wii. According to Nintendo, error code 51032 is:
"Error Code: 51032
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii."
This means there is either some interference with your wireless signal or your router is simply too far away from the wii. You can try to move the wii closer to the router (or router closer to the wii) or try a different wireless channel on your router.
You can see here for nintendo's official solutions to this problem:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51032&system=Wii&locale=lang
Apr 26, 2011 | Nintendo Wii Console
I am having trouble connecting my Samsung BD-C6500 DVD Bluray to my older Linksys G model WRT54GS ROUTER. HOW DO I FIND MY ACCESS CODE AND/OR PASSWORD TO THIS ROUTER.
Unfortunately, you can't find your Wireless Access Code of your router without knowing the password to access your router configuration. It is because, you can only see the Wireless Access Code by going to the router configuration page and in order to go to the router configuration page, you should know the router password.
You should reset your router to default. In order to do this, you can press the Reset button at the back of your router for 30 seconds. Then you can try to use the user name "admin" and password is "blank" or password or admin as well.
Apr 04, 2011 | Linksys Wireless-G WRT54GS Router...
When trying to connect to the internet I get error
Error Code: 5133 Specific Error Code Not Found - General Troubleshooting
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
May 13, 2010 | Nintendo Wii Console
Need to find the security code for my wrt54gs
The security code is the encryption code that is configured in the wireless setup of the Linksys router.
To configure and secure your wireless router from unauthorized access, please click in this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Apr 01, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
