Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Laptop cannot aquire network address from wireless router
Using hp pavillion ze2000 and dlink wbr1310. hardwired desktop connection is fine. laptop finds network, when trying to connect, it asks for passkey, which it accepts, then it says its "aquiring a network address", but nothing ever happens after that. it never even gives up and gives an error msg or anything. when checking status, its sending and receiving data packets with the router, but it just cant access the network.
prior to installing, used a hardwired computer to configure router. set network name, passkey, and set to wpa.
any ideas?
  • 2,263 Answers
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Posted on Apr 30, 2010
I have the same problem with my 1310. I stoped using it as a router and only use it as a wireless access point, and still same problem. the only solution i found to date is to reboot it. then it works fine for a week or so. I loaded new firmware hoping dlink has solved this annoyance. No such luck.
Posted on May 01, 2010
Can't connect to internet
Reboot router. Pull the plug on the router for about minute.
Nov 03, 2014 | Compaq HP 418445-001 PAVILLION ZE2000 AMD...
I am using a dlink model wbr1310 with my desktop. I want to use it with my laptop. would you email me a driver to download to my laptop.
You don't need a driver. If your laptop has wireless capability, you just click on the wireless network that you should have set up with the dlink router and choose "connect." If you have set a passphrase, then you will need to enter that.
Aug 17, 2011 | Computers & Internet
Can conect wireless ,ethernet cable work fine but not wireless
.Log into router ( 192.168.0.1) enter into the browser window.
2. Verify wireless router name( on the computer) >>> ( on/off) on the status page in the router.
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Here is the instruction set for your model router :to set it up wireless follow the emulator instruction at this link:
http://support.dlink.com/emulators/wbr1310_revA/104/wizard.htm
This is for all routers to set up wirelessly.
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Dlink wbr1310 has WAN setup but drops signal every day and the only way to get it back is to unplug and replug the power
try to upgrade the firmware of the router.
connect a computer to the router. check the Ip address on the computer.
open the router set up page.
Click here for more information about router and networks
Jan 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do I secure this router?
First go to the address bar and type in the default ip address of this router: IP address is 192.168.0.1 Then open this link for instructions on programming the wireless security settings. http://www.voiproblem.com/emulators/DLink/wbr1310/support_internet.html
Oct 28, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Desktop prints fine but laptop will not print going through dlink 1260 print server either wired or wireless. I should say I have a linksys router that my desktop is hardwired to, but the Dlink server is...
as no one has answered this I will give it a go .
Check or download the latest printer driver for whatever operating system the laptop is running.
Could be a dhcp server clash from the wi fi print server and the link sys router . Check there are two DCHP servers and if there are deactivate on and use the other .
check the ip addresses in use on the laptop and on the desktop and the printer. make sure subnet mask are all the same but ip addresses are unique but within the network range. eg 198.168.0.2 - 198.168.0.254 and subnet mask 255.255.255.0
or 10.0.0.2 - 10.0.0.254
check the ip address for print server is different to the ip address for the router and make sure DCHP range does not clash with router assigned ip addresses .
Dec 26, 2017 | Toshiba Satellite A205-S5831 Notebook
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Jun 22, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
285 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
