Menu display turned black
My tv menu display becomes black instead of green.
I want to know where the problem is.
Thank you.
  • 8,617 Answers
Will need the model number of your set to be able to help you.
Posted on Mar 25, 2008
Tv turning green need to know what to replace
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 13, 2016 | Mitsubishi Cinema WD-82740 82-inch 1080p...
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
I am in computers. This is either a #1. display that is going out. #2. the video card fails some times, #3. or the monitor is not plugged in all the way. #4. The VGA cable is not firmly attached to the Momputer/monitor. Your VGA IN message that the computer does not have its signal to the monitor that the connection to the computer is good. God Bless
Apr 16, 2017 | Scanport H21 21" LCD Display Monitor
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Green lock and black screen
go to your menu and turn off the ccd and text modes to remove the box,as for your lock out code try oooo or 9999.
Sep 22, 2008 | JVC AV-27D302 27" TV
Display menu
its more than likely a bad capacitor or leaky diode thats giving you the problem. However I cant even begin to give you advice without knowing the model number so I can pull up the service info for your set.
Mar 27, 2008 | Televison & Video
Green tint
Is the green color on displays as well. (Displays means the video generated by changing the volume or activating menu-and seeing if this is green as well. Secondly, turn the color all the way down to zero. Do you see a "normal" black and white picture? If you do, then the picture tubes are not the problem and you have a failure in the color processing area. Let me know....
Mar 07, 2008 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
