Where can I find a reasonably priced FM signal repeater for catching Fm radio and re-broadcasting the signal inside a metal building?
  • 1,284 Answers
Hi you can get it from this link below to check the type you want depending on the price..
http://www.nextag.com/fm-repeater/products-html
Take care
Posted on Apr 30, 2010
Toyota-56037 radio (FM/AM) malfunctions..like... the system receives FM signals 76Mhz to 90 Mhz only although there are a lots of channels after 90Mhz. How to reprogram it? Plz help. TAUFIQ
if there is a mode button , press that and there is fm 1 whch is what you have , press again and you get fm 2 press again and you get fm 3
each fm number is a band width so select the band width that has most pf your stations and then auto select on it
if you have the owners hand book , the procedures are in ti for setting the radio
Nov 17, 2015 | Audio Players & Recorders
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
Cannot find FM Radio on Card
FM radio is ascertained with popular adveretsiments. For example, once ascertain that 106.10 transmits popular enterment media requires to restore to memory. Recent devices recognise the user requests by allowing to search at button feature functions until available signal broadcast were discoved also memorised on device. In situation that the device radio least has auto scan to capture require to manually tune until an available signal broadcast were recognised. Also with devices least with momory features requires to humanly keep to memory the radio frequency. For example 106.10 is recogniseable as party station.
Examples of radio stations
98.1 FM
99.3 FM
94.9 FM
102.3FM
Mar 02, 2011 | Computers & Internet
My Klh r3000 receiver is great for everything except picking up am or fm stations? I had an antenna attached, but the unit is in my basement, and I get no signals at all. What could I be doing wrong?
If the antenna is in a basement that is the problem - the fact that it is below ground means that no signals can get through.
Radio signals are blocked by buildings, large lumps of metal or other solid objects as well as strong magnetic fields (which can include electrical devices within the home).
To pick up good radio reception you will need an external antenna above the ground level - preferably as high as you can get it. Unless you get an omni-directional antenna like this one http://www.maplin.co.uk/vhf-fm-omnidirectional-aerial-874 you will need to point the antenna accurately at the transmitting station (+ or - about 5 degrees) for FM. At a pinch you might get by with an indoor aerial but it needs to be above ground level (inside a roof would be best)
Good external AM Radio aerials are harder to find these days.
Feb 24, 2011 | KLH R3100 Receiver
What does check DAB mean
Dab means Digital Audio Broadcast. It is a radio and a high description radio. It is an audio broadcasting in which the analogue audio is converted into a digital signal and henceforth transmitted on an assigned channel (usually AM or FM frequency range). It put forward CD class audio on the FM broadcast band and to put forward AM class broadcast band on the AM.
Feb 24, 2011 | 2005 Pontiac G6
Wont stop on a station when search button is pressed
The autosearch feature stops on stations based on a preset threshold for radio station signal strength.
If your radio has done this on both AM and FM from when it was new, it is probably an internal problem with the circuit board electronics or possibly because you are in an area where strong signals are absent (such as a rural area or inside a building that interferes with signals).
If the radio won't stop searching at all, the 'Search' button' may be stuck.
If you find that your radio is skipping stations only on FM, it may be a defective or broken external antenna or, again, maybe you are in an area where strong signals are absent (such as a rural area or inside a building that interferes with signals).
Hope this helped.
Feb 03, 2011 | Dewalt DC011 AM/FM Radio
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
What sort of cd stacker will fit my ford radio WF-18805-DLF
get any kind that has an fm modulator.it broadcasts a high quality fm signal around 88mhz fm.
Jul 14, 2009 | Sony XS-L1035 Car Subwoofer
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
AM/SW no longer functioning - FM still works fine
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Sep 15, 2007 | Grundig G4000A FM/AM Radio
16 people viewed this question
 Grubhead
Grubhead
