Question about Water Heaters
I have a Potterton Statesman oil boiler that wont start . We've just bought the house and it had not been used for some time, we filled the tank with oil and when we first turned it on it srarted for about halr an hour then cut out (lock out) , we tryed to reset it but now it wont do a thing.
    Novelist:
  • 135 Answers
There allot of possible problems, usually with an oil tank that has set for awhile, when you fill the tank, it stirs up debre and even water that is in the tank, caused by condensation, it is best to let it set for at least 24 hours to allow it all to settle. The oil pickup tube is usually installed 3" off of the bottom of the tank to help with this problem. Some systems have an external oil filter in the line, this will need to be checked,,, but more than likely the nozzle is fouled, causing the spray pattern to make contact with the electrodes and creating a carbon buildup and shorting them out.
If it is a 2 line fuel system, it will self bleed the air out of the line if you clean the filter, but if it is a single line system, you will need to manually bleed the line, it gets very involved. There are very few good oil men around anymore, but a good place to start would be with your oil supplier and see if they know of a good repair man,
But in the future, to save yourself allot of pain, never let the tank get below 1/3 level and let it sit for 24 hours after filling. On a old system, this is the cheapest and easiest way to avoid problems.
I know this is not what you wanted to hear, but if you have anymore questions, please contact me and please rate me.
Sincerely,
Paul Gibson
Posted on May 03, 2010
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Alpha cd28c boiler loosing water and pressure through pr valve when heating is on,and when then switched off needs repressuring to use heating again.no obvious leaks.new pr valve been fitted.pressure
I assume losing pressure through the PR means Pressure Relief Valve (PRV) or temperature pressure (TPR). Open in TPR may mean boiler is overheating/overpressurized. Open in PRV means the Pressure Reducer/Fill Valve in the fill line of the boiler is broken.
House Water Pressure in a home is 30/40 PSI min to 60-80+PSI max.
Boiler PRV/TPR are set at 30 PSI open (SYSTEM PRESSURE) so too high a house water pressure will open the PRV/TPR. Replace the reduction regulator on/in the fill valve assembly
Oct 20, 2014 | Water Heaters
My boiler has a squeeling sound during the warmu up. I think it is coming from the expansion tank?
The squealing sound generally comes from a circulator pump, if it has a drive coupling between motor and impeller housing there is an oil cup/or oil hole, add oil until it is full! If it is a cartridge style circulator you may have to replace it.
Sometimes air in a system will cause this squeal noise as well. Purging the air out of system may be required. If you need to know how to purge a system there is a good pdf file at this link for $8.95 The Basics of Purging Air
From your Forced Hot Water System
Troubleshooting A Leaking Boiler
Relief Valve
Miller Furnace Books Repair
The Expansion tank is factory set to 12 psi and the only way to tell if it remains with 12 psi is to drop the system pressure to zero and check the tank with a pressure gauge. If water comes out the air valvestem when you apply the pressure gauge, the tank is bad, replace it! If there is less then 12 psi on the tank add air to 12 psi and open water valves back up to normal operating pressure. Usually the feed valve will automatically stop at the preset setting.If the boiler is leaking water out any relieve valve drains, the feed valve, relief valve and or expansion tank may need to be replaced.
Oct 09, 2014 | Amtrol EX-30 Diaphragm Expansion Tank...
Installed a year-and-a-half ago, problems so far: thermostat replaced on hot water tank within one month of installation, one pump replaced, leaking plug in the front of boiler with Dunkirk rep never
Its probably time for small claims court and a new company to install good equipment. Have a couple different companies/contractors give an estimate and possibly expert advice/witness you would then be able to use in court so you can get reimbursed from a bad company. Hope it all works out.
Apr 20, 2013 | Dunkirk Q90-75 Quantum High Efficiency...
I've stripped the threads on the housing while bleeding the boiler. what can i do?
Post question on tank and they may have possible answer for handling that repair under the pressure load of boiler:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Mar 18, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
I have an Amtrol 109 tank on my boiler mounted horizontally (all the literature shows the tank mounted vertically). Lately, the pressure on the boiler slowly bleeds off. I've been told the Amtrol tank may...
If you are losing boiler pressure, it is probably not the expansion tank. Most of the time when these go bad they fill with water and cause a increase in boiler pressure, especially when the boiler is running. If you put a tire gauge on the end of the tank it should read between 10 and 15 psi. If this is the case then the expansion tank is fine. If the tank is fine then you may have a leak somewhere in the system. The perculating that you refer to could also be from the boiler being under filled. Make sure all zones are purged of air and the boiler pressure reads around 12 psi on the gauge. Hope this helps
Oct 24, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Water Heaters Logo
724 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
