Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My lawn mower Troy built B&S 6.50hp/190cc won't stay running.
Starts and then runs for 3 seconds and dies. What is wrong? I just gave it a tune up and it ran fine. Thank you
  • 3,740 Answers
Actually there is still something blocking the carb jet inside the float bowl or... there is a bit of debris in the fuel air mixture screw / needle jet on the side of the carb. This happens more than you would tend to believe on a rfecently cleaned carb. A piece of loose / floating debris gets sucked into the already cleaned carb and blocks a passage.
If you leave the choke on it will probably run but as soon as you take off the choke it dies. i.e. blocked fuel passage somewhere.
Kelly
Posted on May 01, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
My lawnmower starts but does not stay on
If it starts and runs and then slowly dies, it is more than likely your carburator jet is stopped up.With it being blocked, it is starving for fuel. You will have to clean out the carburator and retest. Also check your engine compression.
Jan 17, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My troy built lawn mower dies after it starts runs for a few seconds dies if i put my thumb in the carb it will stay running.
Your high speed needle jet is most likely the cause. Remove the jet and clean it out. Keep in mind that there may be least one or two very small holes drilled in to the sides of the high spped jet, if so, be sure they are cleaned and not clooged.
Jan 17, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy built 6.5 21" lawn mower won't start
take the carb bowl off it may have water in it , that will make it not run
Aug 15, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
962 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
