Question about Fire Magic Aurora A540i-2E1N Stainless Steel Gas Grill
How high is the cabinet under the grill with a 1
How high do I build the cabinet under the grill with a 1 1/4 granite top
for the 540i grill with a liner.
ff.woodworks@yahoo.com
  • 8,197 Answers
The finish height should be 36" from the ground. So you need 34and 1/2 inches then you need to put 3/4" concrete. Then the granite that should be 3/4". You can fudge a little with in 3/8 inch if you need.
Posted on May 01, 2010
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
There were no instructions to install my undermount sink. What can I do?
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
May 15, 2010 | Franke 34" Undermount Double Bowl...
I have granite countertops< so i have to install the clips on the sides of the dishwasher instead of on top. however the dishwasher has no holes with plugs
If you can't find any place on the sides to mount the clips then you can take a piece of wood that matches your cabinets and fasten it to the opening in you cabinet for the dishwasher so you will have somethink to mount the washer to. Make sure your washer is level so you can figure out the gap size at the top, then pull the washer out and mount the wood to the cabinet. You could call the guys who installed the counter tops and see what they would or could do, but I wouldn't drill into the granite myself
Jan 07, 2010 | Dishwashers
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
Dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
Sep 11, 2008 | Viking DFUD042 Built-in Dishwasher
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Jun 25, 2008 | GE Dishwashers
Fire Magic Aurora A540i-2E1N Stainless Steel Gas Grill Logo
57 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
