Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Whirpool side by side refrigerator hot door gasket
I have a whirpool side by side refrigerator model#GD5SHAXLB00. The gasket in the middle of both doors is very hot. I just cleaned the coils at the bottom behind the cover/grill. They were very dirty. I pluged it in and the gasket became hot again. What else could it be?
    President:
  • 1,218 Answers
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Posted on Apr 30, 2010
3 door maytag refrigerator - bottom door is stuck on one side and will not open.
Accumulation of gunk or even ice on the door gasket can act as a glue between the door gasket and the front edge of the unit. Try using a rag, soaked in hot water and wipe the side of the gasket to try and loosen the gunk or ice.
Apr 18, 2015 | Maytag Refrigerators
We have a side by side Whirpool Ref Model #ED25PQ. It makes ice and despense ice inside the ref into the ice tray. Our problem is with the door closed we are unble to get ice thru the door into the...
I don't know if this is your problem, but my sister had this problem before. When I checked the area, it was clogged with dried soda. The kids allowed it to splash up when ice dropped into the glass. The sugary drinks will dry sticky and not allow the dispenser to dispense. I used very hot soapy water several times to melt the sticky buildup. Her fridge has been working every since. Good luck, it this is your solution
Aug 18, 2013 | Whirlpool ED5FTGX Side by Side...
Hot on middle bar between doors. Both rubber gaskets are hot too. seems to be working but running hard and making noise. Its making ice and water.
Hello, Thank You for using FixYa. I will be helping you today.If it is hot to the touch it is either because the condenser fan failed or the condenser is dirty.Check the fan in back of the unit make sure it runs when the compressor is on. If it doesn't run with the compressor replace it. If it does then you need to clean the back vents in the cardboard and under the front of the unit. One of these will correct your issue. This area should be warm at times just not hot. It prevents moisture.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | KitchenAid KSCS25FKSS Side by Side...
Freezer door does not close properly
inspect the seal all the way around the door. check to make sure that it is not in a bind when you open and close the door. if it is you can try a little wd40 or silicone spray on the gasket and frame of the refrigerator where the gasket meets the frame. this will help it slide accros the frame better.
if the gasket is bound up and out of shape, you can heat it up with very hot water to straighten it.
make sure that you keep the gasket and the door facing clean. spillage from the use of the refrigerator/freezer can cause the gasket to stick especially at the bottom.
Jul 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator get's hot when plugeed in
It is normal for some heat to be generated in this area. However there is something you need to check if you feel the heat is excessive.
In the lower rear of your unit is the compressor and a fan. You need to look the see if this fan is operating. Its quite common for this fan to get jammed during a move because the insulation gets caught in the blades of the fan. It is very important this fan is operating as it cools the freon and oil which in turn cools the compressor. The heat you are feeling is part of the warm side of the circulating system that was installed there to help keep that area dry and your door gaskets free of mold.
Thanks for asking.
Jun 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Panel between doors is hot
Many models of refrigerators have a heating element around where the gasket seals to the fridge. This is to prevent ice buildup around the doors that would prevent the doors from closing all the way.
If you haven't noticed any other problems with the cooling of your unit, you're refrigerator is running exactly the way it was designed.
Mar 26, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
Oct 21, 2009 | Whirlpool Refrigerators
Inside the door panel
If you mean the area where the gasket is...yes.  This is a mullion heater designed to prevent freezing the gasket to the box.  It should be slightly warm.  Some units have the option of turning thi feature off.  Check your manual.
Nov 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
