Question about Exercise & Fitness
My treadmil is running but when i stand on it it starts to like skip and if i walk on it i will fall what could be the problem and it runs fine when im not standing on it as soon as i stand on it it skips
  • 83 Answers
Please check out this tip I wrote. Please let me know if you need anymore help.
Posted on May 01, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=b1MU7MvBETs
https://www.youtube.com/watch?v=JC72OIKdluY
Dec 27, 2015 | Bodyguard T240 Treadmill
Belt problem ...
Hi Paula, I know nothing about it, you could lift the belt and use DW40 or vegi spray where it's squeaking. Nothing beats a walk in the park. Greg.
Apr 27, 2014 | Proform 680 LT Treadmill
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
My treadmill starts up and run but when i stand on it the belt stop rolling but the motor is still going
check tension on w/belt and motor belt signs of worn out belt. black dust cracking treads or flaking.
Mar 13, 2011 | Proform 530 Treadmill Walking Belt
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
When i start running it isnt a steady flow of the belt there is jerks every few seconds making it very hard to run and almost is enough to make you fall what do you think the problem might be
It sounds like you either have a loose walk belt or a slipping front drive pully. The walk belt shoould be tightened so that you can pull up on the edge of the belt about 2 inches. If that is OK, pull the motor cover, start the treadmill and walk trying to stop the belt with you feet. Watch the drive belt this time (the small one going from the drive motor to the front drive roller), if this belt stops, you need to tighten motor, or replace if it is older/wornout. If the drive belt keeps turning fine, watch the front roller and see if the pully connected to the drive belt keeps turning while the roller connected to the walk belt stops, if so you need a new front drive roller.
Hope this helps
Nov 03, 2010 | Epic View 550 Treadmill
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
Nov 02, 2010 | Proform 680 LT Treadmill
Belt skips
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2010 | Proform 540ls Treadmill Walking Belt
What do i do when the belt skips while u are on it?
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Jan 12, 2009 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
73 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
