Question about Star Logic 17" LCD Monitor
LCD I have a Logik lcd 15 inch and I want to use it as a PC screen. when I attach it to a PC only the half of the picture comes up and the writing is illegable
  • arvind kumar May 11, 2010
    sir/mam
    In monitor setings will there please set with the scree. in system we have om monitor with mouse left clike and properties and go to settings ok
  • 180 Answers
Have tried checking your display card by connecting another LCD to your computer ?
Or you can try your LCD to other computer.
Posted on Apr 20, 2008
My Logik TV 74cm is now showing half pictures and there is no full screen. when turned on it would be a quarter picture then it goes to half, and finally 3/4
T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 28, 2017 | Televison & Video
How do i fix my 50 inch element lcd tv has picture that is half blue and half picture
you cant
its most likely that the lcd drivers attached to the lcd is shot , its because lots of these tvs have no cooling fans so the solders become brittle. or some one hits the front of the screen an it will damage them.
its a trick to fix them if its even possible
other wise the video board has gone south from some capacitor thats dried is 2nd choice.
id not wast the money fixing it because your guess would be wrong most likely.
Sep 08, 2014 | Element Electronics Televison & Video
Half the screen has picture and the other side is all black
lcd tv's screens are actually made up with 2 parts a left and a right side each having its own video feed with generates half of the image each and sincs them which to the viewer appears as 1 full screen. if your screen is missing half of the image and it is exactly occurring inn the middle of the screen them the video signal probably isn't making it to that half of the lcd. either the video board is falling or the ribbon connector from it to the lcd has failed or possibly the connection where it is attached to the lcd (which saddle isn't reparable and would require replacing the lcd panel) the first 2 mentioned are an easer/cheaper fix . you can usually check the lcd connection buy removing the back gaining access to the connectors and see if the image appears on the screen while applying pressure along point where the connection goes into the lcd. if it does then the connection had come loose and as far as i know theres no way to reattach it.
Mar 17, 2014 | Samsung LTN1535 15 in. HD-Ready LCD...
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
Logik tv
I just experienced the same issue that is described in the previous post. I went through all of the standard trouble shooting modes.
  • Powered down the LCD
  • Switched HDMI cables
  • Checked and reset all connections (even unrelated devices)
I finally got a picture when I made a straight cable connection. I have a sling box attached through my cable box and noticed that the picture was fine when viewed on my PC. I thought it had to be a problem with the LCD. As a last ditch effort I powered off my DVR box, it must have reset the signal from the cable box to the television because everything is working again. I hope this helps you.
Television: 46" Sharp Aquos (LC-46SB54U)
DVR: Scientific Atlantic Explorer 8240HDC
Feb 01, 2009 | Televison & Video
Dark screen on me laptop
the LCD backlight has failed, you will need to replace the LCD assy (about $200)
Jan 18, 2009 | Dell Inspiron 5150 Notebook
Use logik LCD as PC screen
Either the vga cable not plug in carefully or your display card is defect.
Mar 19, 2008 | Star Logic 17" LCD Monitor
Top inch and a half of tv picture cut off.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Oct 16, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Star Logic 17" LCD Monitor Logo
73 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
