Question about Acer TravelMate 2300 Notebook
Acer Travelmate 2410 with display probs
Thanks but i've already tried to adjust this by dropping the res to 800 and down to 16 bit. Also, this happens in both linux and windows o/s. The screen was running fine for a while then would kick in with the funky colours for a while. Sometimes it sorts itself out immediately, other times its for hours. It's almost as if the grphics is on its way out. Presumably all i can do is replace the board. Just a note, the dc jack was damaged and was repaired (rather shoddily) using a wire from the bottom to the top of the board. All I can think of is that the connection is touching/arcing onto the graphics on the motherboard? As yet i've still to hook it to another screen (I tried b4 but by the time I did the colours sorted themselves out). Any other suggestions would be helpful.
    Scholar:
  • 105 Answers
Most laptops use graphics that are integrated on the motherboard. These graphics use a large integrated circuit which is connected to the motherboard by BGA., this stands for "ball and grid assembly" There may be 200 + connections of this type under a graphics IC. It is probably an intermittent failure of one of these connections. They are not usually repaired - replacing the motherboard is the usual option. However if using an external monitor there are the same display problems - then it is almost certainly the problem I have described. Flexing the board when the DC connector was replaced could have contributed to the problem - or if the wire added was causing the motherboard not to sit properly down - fitting the motherboard screws could cause the board to flex by the BGA chips.
I am supplying this information as you required more knowledge on graphics failure. This information should be useful. We depend on you rating the assistance given. I would appreciate a good rating - as it is very difficult to fix a particular item when we are asked general questions - I hope having some idea of BGA circuitry will explain matters. Please rate this solution.
Posted on Mar 25, 2008
  • Anonymous Apr 02, 2008
    Please rate my help - this was given free - but we rely on your feedback!
SOURCE:
Need to speed up my Acer Travelmate 2410
According to your describe, your slow TravelMate laptop can caused by various hidden Windows errors. Those problems firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden! To quickly fix the problem, see resolution here: http://www.speedupacer.com/ Should help you out, good luck!
Dec 29, 2008 | Acer TravelMate 2300 Notebook
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
TRAVELMATE 2410
hi buddy!
check the videocard and sound card if installed already right click the my computer,properties,hardware and device manager and if have a yellow question mark means not installed
and also check the cable wire if in the good condition ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 08, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2410
Here is the url for all your Acermate 2410 drivers...scroll down, they are all listed there for any and all OS's.
http://www.driverstock.com/Acer-TravelMate-2410-driver-download/4-21-12907/index.html
~~Jasta~~
Apr 03, 2008 | Acer TravelMate 2300 Notebook
Vista Services Don't Work On My Laptop! Acer Travelmate 2410!
wow..that's three or four apps? Did they come with the Vista machine?
Mar 13, 2008 | Acer TravelMate 2300 Notebook
Could be the screen is running with the wrong colour depth and resolution - reset the settings by right clicking on the screen selecting properties and then adjust on the settings tab.
Mar 10, 2008 | Acer TravelMate 2300 Notebook
Upgrade RAM
hi, to upgrade your laptop's memory here's the info you need to order the new module or modules http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?id=1&SysID=25068&mfr=Acer&model=TravelMate+2410+Series+2413%2C+2418%2C+2419&root=&LinkBack=&Sys=25068-Acer-TravelMate+2410+Series+2413%2C+2418%2C+2419&distributor=0&submit1=Search regards
Aug 18, 2007 | Acer TravelMate 2413LMi Notebook
Computers & Internet Logo
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
