Question about Kenwood VR-507 Receiver
Remote don't work it work intermittently.Tried a logitech harmony and it does the same work when it want to. Need help
Since this issue is happening with both the original remote and the Harmony remote, it is more then likely a problem with the IR receiver on your device. If I were you I would call the manufacturer if it is still under warranty. Otherwise, someone on here may know how to fix it.
Posted on May 09, 2010
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
I have the harmony 659.I have had this device for years.I am now having an issue and need the software for said device which i don't have. where do i get the software i need
Hi, The Harmony Remote Software is free, and can be downloaded from Logitech's website. The link is:
http://logitech.com/myharmony
On that page, click the link for either PC or Mac, and the software will download.
Hope this helps.
Jul 13, 2011 | Logitech HARMONY 659 Remote Control
I have a Logitech 670 Harmony Remote control. When I tried tro update the software and firmware the display is now stuck on "Start the Logitech Harmony Remote Software to update settings". How do...
Do a firmware update again in safemode. Press and hold the "off" button, and then plug it into the computer, and continue with the firmware update. If this doesn't work, I'd call technical support.
Jun 12, 2011 | Logitech Harmony 670 Advanced Universal...
My harmony 520 simply stopped working.
Have you tried resetting your Logitech Harmony 520 remote by updating your remote's firmware? Firmware replacement fixes several Harmony problems.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Apr 10, 2010 | Logitech Harmony 1000 LCD Touchscreen...
On the screen of the Harmony520, it just saids Harmony and nothing else and i can't acsess anything. how do i get out of this?
I hope that helps.
Oct 23, 2009 | Logitech Harmony 520 LCD Remote Control
Harmony 520 glow light won't turn off. I have updated the software and tried all the suggested fixes. Is there a way to disconnect the glow light.
The problem with your Logitech Harmony 520 backlight staying on is with the timing crystal.
This is a solid state component that is responsible for telling the remote when the light has been on long enough.
It is very common in these remotes for the timing crystal to fail, thus your glowlight stays on until the batteries are dead.
I am not aware of a way simply disconnect the glow light.
If your Logitech Harmony is under warranty, contact Logitech Support (1-866-934-5644) to have your remote replaced.
If you are handy with soldering solid state electronics, the part you want to replace looks like a capacitor. You can buy what you need from any electronic parts store or hobby shop, just ask for a 32.768KHz crystal.
I hope that helps.
Harmony Mac Software Download
Oct 10, 2009 | Logitech Harmony 520 LCD Remote Control
I need the code for a Teac CD-X10i mini hi fi system
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
Aug 19, 2009 | Logitech Harmony 520 LCD Remote Control
Safe mode!
I can help you with your Harmony One Remote Control.
Replacing the firmware in your Harmony One is the way to get it out of Safe Mode.
To help you make sure the firmware update is successful:
  1. May I suggest you make sure you are running the latest Harmony Setup Software (V 7.7.0).
  2. Replace your remote's batteries with fresh ones. It is important the remote has sufficient, unvarying power when updating firmware.
I hope that helps.
______________________________________________
Harmony One Manual Download
Apr 18, 2009 | Logitech Harmony One Advanced Universal...
Cannot get DVD to play movies -
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
Harmony 890 Manual Download
Harmony MAC Software Download
Feb 02, 2009 | Logitech Harmony 890 LCD Remote Control
Kenwood VR-507 Receiver Logo
157 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
