Question about Music
The LCD display on our yamaha DGX620 has disappeared: it lights up but there is nothing showing on it. Have tried adjusting the contrast button with no success. Any ideas please? Gill
I have the same problem after lending it out to someone, could it be that it was left on for a long period of time ? did you find a solution yet?
Posted on Jun 18, 2010
  • Music Master
  • 5,603 Answers
I would open the unit and see if a cable to the display has fallen off.
You have not mentioned if unit is operating except for that.
If totally inopperative, check power supply to the unit. The display can illuminate well below the operating voltage for the synth.
Posted on Apr 30, 2010
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
How do I adjust the contrast on the display screen of my yamaha ypg-535?
There is a contrast control knob on the rear panel of the instrument.
Oct 20, 2015 | Yamaha YPG-535 88-Key Portable Grand Piano
Screen is blanck can not see any of the database
If you haven't already, try to adjust the LCD Contrast by rotating the knob on the rear of the keyboard. If that doesn't help and if every thing else functions the Contrast pot is damaged or the LCD needs to be replaced. Those would be the most likely causes.
Dec 11, 2014 | Yamaha DGX 640 Keyboard Arranger
Roland pad 80 is it normal for the lcd display to show a bar of squares and nothing else when pluged in to power and not pluged into anything else?
The Roland Pad 80 has a contrast control, if it's not correctly adjusted, it could cause it to appear all black or all blank.
If the LCD were bad, it's uncommon for both sections to both go out around the same time, since it uses two seperate 7 segment LCD components. About the only way to cause both to go out at about the same time, would be to get the equipment wet, or let it get way too hot or left sitting out in the sun, long enough to dry up the "liquid" part of "Liquid chrystal display".
Oct 15, 2013 | Music
Only blue light with blank display on power on
Dear Joseph,
I had similar problem with my DGX620. In my case the display sometimes got blue and sometimes worked fine. The cause was a bad contact of the display flat cable.
I opened the DGX620 and then I cut a small piece of plastic film (35mm negative) with exactly the same width of the flat, disconnect the flat cable and then reconnected it using the film on the other side (non contact side) to increase the pressure and guarantee a good contact. No more problems from nov-2012 till now.
Good luck !
Paulo de Tarso (Brazil)
Nov 14, 2012 | Yamaha DGX630 - Digital Piano
DGX620
If the backlight is on and just half of the display data is there, it is probable the conductive strip has come away from the display or the contact portion of the board where the conductor strip lays on the circuit board.
If it is under warranty, contact Yamaha. If it not under warranty, you can try to fix it, but once adhesive lets go, it is diffeicult to get them to premanently readhere. A repair shop that is Yamaha authorized is able to get the New parts from Yamaha that fit.
Apr 10, 2012 | Yamaha 88 Key Portable Grand w/stand
Affichage presque invisible
try adjusting contrast, and try a different lighting source. If you have a polarized light source currently, try orienting it 90 degrees from where it is. That type of LCD relies on reflected lighting and it uses polarizing filters, so you may be at maximum contrast, but the current lighting is being absorbed by those polarized filters. Plus LED lighting, if not the right light frequency too- it gets absorbed. I have a clock in front of me that is exactly that way
Feb 05, 2012 | Alesis Sr 16 Stereo Drum Machine
It turns on but there is nothing showing on the screen.
There is a contrast control that will totally blank the display. Read your users manual page 25. Adjust the control as needed for visibility.
Sep 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Apr 03, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
353 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
