Question about Proform 980 CS Treadmill
The proform 980 turns on but just goes to incline
I have the proform 980 it turns on but just goes to incline then goes down. I cant press any buttons to make it stop or use it to run on.
    President:
  • Proform Master
  • 832 Answers
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Posted on May 06, 2010
My treadmill won't go down the platform how to lower it please help
If it is stuck in the incline position all you need to do is re-calibrate most of the time
The first step to re-calibrate the incline. ProForm provides calibration instructions in the treadmill owner's manual.
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons.
Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp. Press the "Stop" button and remove the safety key.
Hope this helps or solves the problem, if you have any further questions please do not hesitate to contact us at 888-713-2880 or visit us online at
http://www.sportsmith.net/supportsearch.aspx
May 18, 2015 | Proform 1050T Treadmill
Why won't incline go up or down?
Calibrating Your Incline Is your incline not operating correctly? There are a few simple steps that can be followed which will most likely resolve that problem for you.
9bvipvsqvatex9kgfcnn03s5zhvtng9too4023mrox7s22mjjuue73rxrrhupctrxro022nhu0i53bbtrxqocdrxro402hhw0410bbbtxqkad79poo41hbe1410ybbtwq+p8byj8qzuzzwaoaaaaasuvork5cyii=
The first step is to press and hold both the STOP and SPEED INCREASE buttons, this will be either an UP ARROW or a + (plus) symbol. While holding these two buttons down you will need to insert your safety key.
Once you have inserted the safety key you can release the buttons and let go of the key. At this point you will need to press the STOP button one time. Congratulations, you are now in Calibration Mode.
Now that we are in calibration, press the INCLINE UP button one time. This will cause the platform to go all the way up and then it will come all the way back down again.
Now that the incline has stopped moving you can remove the safety key.
Parts for ProForm Fitness Equipment Treadmills Bikes Ellipticals Belts...
Apr 26, 2014 | Proform Sport 1000 Folding Treadmill...
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Jan 04, 2011 | Proform CrossTrainer Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
I have a proform xp 580. when I turn it on,
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
My treadmill proform835QT fails to incline. What can I do?
Try to calibrate the incline: Hold down the stop and speed up buttons at the same time then insert the key. release the buttons the press the stop button and release then press the incline up button. the incline motor should go all the way up then all the way down with - - on the console. If the unit only moves just a and inch or so or the motor just hums , the incline sensor is faulty.
Jan 15, 2010 | Proform CrossTrainer Treadmill
My ProForm 530 is stuck in the incline position. Once the key is inserted, the treadmill is steady trying to incline past 12 and does not respond to me pressing the ''incline down'' button. It continues to...
plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
Jan 05, 2010 | Exercise & Fitness
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Proform 980 CS Treadmill Logo
262 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
